Thread: Tekin ROC 412 crawler motor what is the best esc to run with it.
Old 03-12-2013, 11:01 AM   #1
Default Tekin ROC 412 crawler motor what is the best esc to run with it.
What would be the best esc to run with this motor. I want a crawler esc and water proof if posible but it dose not have to be. I was thinking about geting the tekin FX-R pro.
motoxkfx is offline   Reply With Quote
Old 03-12-2013, 11:06 AM   #2
Default Re: Tekin ROC 412 crawler motor what is the best esc to run with it.
I'd get either a MMP or Tekin RS. My personal preference is the MMP. It can run any motor you want and is 6s lipos capable. IMO its the best do everything esc there is.
crawler nut is offline   Reply With Quote
Old 03-12-2013, 11:10 AM   #3
dose the mmp have a drag break. also my motor is sensored.
Old 03-12-2013, 11:45 AM   #4
MMP is a do all esc. The Tekin RS is a nice esc as well, has a smaller footprint than the MMP. If you have a CastleLink, I'd go with the MMP. Yes, it has drag brake features and will work with a sensored motor.
Devil Inc is offline   Reply With Quote
Old 03-12-2013, 12:18 PM   #5
ok cool and thanks i have it on order should get it thursday.
Also what do you all think about the motor was it worth the 150 i payed for it. its a tekin roc 412 2300 kv brushless sensored motor 4 pole 12 slot high torque.
Old 03-12-2013, 12:22 PM   #6
MMP all tha way. That wAt i run and its perfect. And they can be found used for a really good price... U can use tha money u save not gettin the RS to replace broken partz The best set up for the wraith IMO. And i have tested MANY. Hope this helps. Later
lowlow is offline   Reply With Quote
Old 03-12-2013, 01:24 PM   #7
I run a mmp and a tekin pro4 from what I have read the roc 412 is very similar. I'm planning on ordering one for my son's wraith once he wears out the stock brushed motor. I don't think you can go wrong with the combo. I run 32p gears with 58/11 gearing and it barely gets warm and is smooth as glass down low.
wildmanMG is offline   Reply With Quote
Old 03-12-2013, 02:26 PM   #8
dont think im going to break much got about everything done to it that i can to make it reliable all hardened steel gears throughout aluminum trans case mip driveshafts and a ton of other things.
Old 03-12-2013, 02:30 PM   #9
thats good to hear that it is smooth down low that is really what i am looking for. but i do want some wheel speed to get me up the hills.
Old 03-12-2013, 02:43 PM   #10
shit man your good to go... i have the 3300 or watever kv it is and its SICK... i keep the MMP set on low pretty much all the time, med is almost uncontrolable how fast it is.. high, well i dont know and cant imagine.. looks good!
Old 03-12-2013, 02:45 PM   #11
Run it on a 3S lipo. That will get you some wheel speed.
Thats the combo I run.
You can change ther throttle curve in the Castle link software to make the first half of the trigger very smooth. The last half of the throttle will do backflips.
BurnLatex is offline   Reply With Quote
Old 03-12-2013, 02:50 PM   #12
I've got a ROC412 3100kv and MMP on the way, should be interesting...
Old 03-12-2013, 04:21 PM   #13
Very nice, how does everyone like the ROC412 motors?
cmnyj28 is offline   Reply With Quote
Old 03-12-2013, 10:50 PM   #14
I am running the MMP with a ROC412 2300kv, stock gearing on 2s. Had a 35T brushed and the ROC412 crawls better and has more wheel speed than the stock motor. I have no problem getting up steep dirt hills now.
wrangler is offline   Reply With Quote
Old 03-13-2013, 09:45 PM   #15
im not sure hell be doing backflips with the 2300kv motor but will have pretty damn decent wheel speed with 3s and still a jogging pace on 2s.
i run a 2100kv motor and on 2s the stock rtr wraith is just a tiny bit faster.
i think id leave the throttle curve alone dont want it feeling mushy anywhere. however with alot of power ontap might tune in some punch control. im running 50% on my punch control to keep from twisting the wraith in half
evan03 is offline   Reply With Quote
Old 03-14-2013, 10:54 AM   #16
will do i got the speed control today and am going to install everything when i get home tonight.
Old 03-15-2013, 07:52 AM   #17
I'm running 12/58 with the 3100 and it's perfect on 2s. On 3s it will pull a wheelie and ride it for about 15 feet. I have upgraded my rear driveshaft, but pretty sure the gears in the tranny will let go first.
ik632 is offline   Reply With Quote
Old 03-15-2013, 08:42 AM   #18
well i got it all put together and it is perfect crawles great and plenty of wheel speed on 2s for me and the toque is crazy and i finely have drag break.
Thanks everyone for the advice.
Old 03-15-2013, 08:57 AM   #19
Just picked up my MMP & 3100 from the post office this morning. I've been curious about running 3s on it. Couldn't really find any good videos. I've upgraded the trans gears to HR steel ones, HR spools, overdrive and stock ratio hardened diff gears. Ordered and on the way are a Gen3 slipper, SuperShafty top shaft, MIPs, biggin69's Beef Toobs. Oh and I picked up some Traxxas bushings to strengthen the diff pinion gears by taking some stress off the bearing. I've kinda sparred no expense on this build. Now I'm just waiting for SuperShafty to release his new motor plate to the public. Lol
Old 03-15-2013, 01:02 PM   #20
Cool thing is the curve is easily adjustable. I got to thinking and it might not hurt to make a linear curve that tops out at 75-80% this would mellow out the entire throttle range. If you try something its no big deal.
May also play with punch control to tame wheelies or tune for riding wheelies ;)
Tekin ROC 412 crawler motor what is the best esc to run with it. - Similar Threads
Tekin Pro4 vs. Roc 412 crawler nut Electronics 51 05-04-2014 09:14 AM
TEKIN Christmas Giveaway! - ROC 412 Crawler Motors Ty@Tekin Electronics 598 10-21-2013 07:30 AM
MMP and Tekin Roc 412 Onebdgti Electronics 0 02-23-2013 08:07 AM
Christmas Sweetness - Tekin Roc 412 GrimJeeper91 Team Losi Comp Crawler 6 01-01-2013 05:47 PM
Tekin ROC 412????? Soulo747 Electronics 1 12-09-2012 05:18 PM
