10-08-2017, 06:10 PM | #41 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: New axles for my wraith
I still prefer the Original axles from axial AR60 with Eric's modified big bearings off cause |
10-08-2017, 11:44 PM | #42 |
Im loving my boom racing ar60 phaties there heavy and take a beating they realy plant the rig i installed a integy axle for a freind it took a bit of work to get it the truss to line up all the hol3s were off by just alit5le bit and the gears needed shimming every witch way as everything is loose inside but after it was properly set up it works fine as good as any other axle the copo axles went together better and look better but i dont think the quality is there the advantage to the centered pumpkin axle has to do with axle wrap the longer shaft wraps more than the shorter shaft causeing it to pull to one side under alot of power but its only a issue on pavement under hard exceleration
