03-24-2013, 11:40 AM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Shock setup
I am building my wraith for trails and crawling only. Should I run one hole pistons or 3 hole pistons?
03-24-2013, 11:58 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Re: Shock setup
I would experiment with what works for you best |
03-24-2013, 12:02 PM | #3 |
| Re: Shock setup
3 hole pistons are the softest right?
03-24-2013, 12:08 PM | #4 |
| Re: Shock setup
Yes, I generally run a softer front then the rear and run a one hole on the left rear to help with torque twist but thats me... I also run internal and external springs... You can also drill out the holes to make them softer...Its all personal preference and find what works for you and your driving style, cause everyone is different and everyone is going to have an opinion... |
03-24-2013, 03:38 PM | #5 |
| Re: Shock setup
I think I got it dialed in today. Took it out on its first trail run and it did great! It could be a little taller to get over some stuff but then I worry about it getting top heavy and rolling.
03-24-2013, 06:04 PM | #6 |
| Re: Shock setup
Mt slayer sits low and does pretty sang good . I shoot for level ride height so I'm slightly stiffer in the front to compensate for the extra weight up front. |
03-24-2013, 06:30 PM | #7 |
| Re: Shock setup
My lower links are almost parallel to the ground and it sits pretty level
03-24-2013, 06:34 PM | #8 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
If you're looking to go "softer" or "stiffer" you need to be adjusting the spring rates. You can adjust this a little with preload spacers/collars, or by changing the springs all together. The only thing the shock piston does is control the oil's rate of transfer from one side to the other. You can fine tune this by changing the oil weight. Lower weight faster transfer & vice versa for higher weight.
Shock setup - Similar Threads | ||||
Shock Setup | CantonAreaCrawler | Redcat Crawlers | 5 | 09-26-2012 04:50 PM |
Shock setup | JON0529 | Axial SCX-10 | 4 | 07-01-2011 08:11 AM |
Shock setup | vti-chris | Newbie General | 22 | 03-29-2011 08:14 PM |
Shock Setup? | rcjackson0926 | Axial XR10 | 6 | 12-31-2010 07:15 PM |
My shock setup | scorpion_king | General Crawlers | 7 | 05-04-2007 06:37 AM |
