04-15-2013, 07:44 PM | #1 |
| Szczerba's Wraith Monster Truck Build #2
Took the Snoopmax MT chassis and tweaked the design a little bit to come up with what you see below. Had friend make the CAD modifications and cut it out in 1/8" delrin too. 13.5" wheelbase, 100mm shocks. More parts coming in the mail. In Super-Mock up mode right now. HPI body is the only one I had laying around. |
04-15-2013, 08:12 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: Norway
like this already;) subscribed
04-15-2013, 08:35 PM | #3 |
Pebble Pounder Join Date: Apr 2012 Location: Bellingham
Rad.
04-16-2013, 11:44 AM | #4 |
| Re: Szczerba's Wraith Monster Truck Build #2 |
04-16-2013, 05:21 PM | #5 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
Love it. Looking forward to seeing it finished. |
04-16-2013, 09:46 PM | #6 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
awesome build. Interesting things coming from you workshop. |
04-17-2013, 07:16 AM | #7 |
| Re: Szczerba's Wraith Monster Truck Build #2 Thanks guys . I built up a tubed Wraith MT then Eddid from Crawler Innovations pryed it out of my hands. http://www.rccrawler.com/forum/axial...ml#post4183542 And then I stumbled upon a guy "SnoopMaxx" that had some CAD files of the chassis shown above. Made a few changes and had them cut by a friend with a CNC Router. Used 1/8" Delrin. Setup for a AX10 Skid and transmission. Wheelbase is 13.5" |
04-23-2013, 03:37 PM | #8 |
Top Kick body mock up. 14" WB. |
04-28-2013, 12:02 PM | #9 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
Body looks good on that chassis!
04-28-2013, 12:04 PM | #10 |
05-01-2013, 07:32 PM | #11 |
Got everything in for a mock up test run. Handles pretty good for being just under 7lbs. Will need a little bit of shock tuning and some mods to keep the rod ends on the Ti links. Busted the upper cab because I left one cross brace off by accident. No fault in the chassis geometry, just me failing to see the brace holes cause the CNC didn't cut all the way through. Modded up these clod wheels with some DLux beadlock faces and SLW hubs Got in some OFNA and TXT wheels as well. Tekin Pro4 4000kv Mamba Max Pro 11.1v lipo 12/54 gearing Last edited by Szczerba; 05-24-2013 at 12:45 PM. |
05-02-2013, 08:13 AM | #12 |
Quarry Creeper Join Date: Jun 2011 Location: Ogden
It looks like a big, mean scale truck with those pit bulls! Thanks for the pics and vids Shane!
05-02-2013, 08:28 AM | #13 | |
| Re: Szczerba's Wraith Monster Truck Build #2 Quote:
I should probably turn the throttle EPA down to 60% or so. The truck is super light for a MT but the big 1lbs rubber weights on the end of the axles make it hand funky. Need to sand them down and see how soft I can get them. I have a second set of tires if I screw up the first. Also, the wraith universal up front are pretty sloppy and cause some front end chattering need to shim them up or get some VP axle shafts. | |
05-02-2013, 11:33 AM | #14 |
My universals are sloppy too - gonna shim. Are you running stock foams in the tires? Maybe cut them a bit too for some better softness
05-02-2013, 12:31 PM | #15 |
Stock foams no trimming on this set. Ill hack up the other set. Foams and tires!
05-02-2013, 02:14 PM | #16 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Have you had a look at the rpm rod ends? They might help out. RPM Short Heavy Duty Traxxas Style Tie Rod Ends 12 80475 Blue Ball Links | eBay |
05-03-2013, 08:00 AM | #17 | |
05-04-2013, 03:31 PM | #18 |
Made some brackets to double shear the lower link mounts Shaved 0.5oz off each tire Made some quick sway bars from coat hanger wire Made a quick elecs tray Figuring out a body mount set now 6.5lbs RTR without body |
05-04-2013, 06:41 PM | #19 |
Did you have black boogers after sanding the tires? That's light. My Emaxx is right at 10 lbs rtr. And it's set up fairly light, one servo, no aluminum, race truggy wheels/tires, etc. |
05-04-2013, 06:45 PM | #20 | |
Yep. Really light setup. No oil in the shocks. 20wt was a little too stiff. Traxxass big bores with Losi golds. Coat hanger sway bars helped out I kind like having the front sway bar only. | |
Szczerba's Wraith Monster Truck Build #2 - Similar Threads | ||||
Szczerba's Monster Truck Build on AR60's | Szczerba | Mega/Monster Trucks | 105 | 03-11-2015 08:19 AM |
Wraith monster truck build #3 | william g | Axial Wraith | 15 | 02-23-2013 10:47 AM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Monster truck wraith? | strap624 | Axial Wraith | 8 | 09-12-2011 01:24 PM |
