07-19-2013, 01:02 AM | #41 |
Rock Crawler Join Date: May 2012 Location: Upland
Can you show us where that front light is mounted? Sent from my PG86100 using Tapatalk 2 |
08-06-2013, 10:54 PM | #42 | |
It will be something I'm goin to be working on in the off season for the future. It will be mounted to the back of the front bumper, using CRAWLER-DAD lights, with the lights inside the bumper loops. (That was just mach up, then comp season took ahold of my time) | |
08-06-2013, 11:05 PM | #43 |
Couple changes. As my sons(8yrs old) wraith came 4ws, I traded off his servos for a 7950, an sold the VP cms's an pan hard kits. Just front wheel steer. He is now rocking a Dinky S mount, like dad, and he now has a hitec 7955, cc bec, tekin RS an 13.5t redline with 32p 58/11 gearing. A little much? Maybe.. but he wasn't happy not bein able to do the hill climb, up the road, at the edge of the cemetery. (That starts our trip together) I put the 7950 on mine and Finally got around to painting the rear dinky drop bed for mine. Hit it with rubberized bed liner first, then a coat of black. (It needs to get dirty!). After seeing it on my rig, I can tell he will Need one next.. lol.. I also started back on the H1 proline cut up body to go on mine. But that's a later update.. |
10-20-2013, 09:22 AM | #44 |
Small bits.. ruined another front gear set.. Awesome! So dropped in a stock set for now. While I had it apart I pulled the vvd's for a fresh set of uni's. I modded them like the XR uni's. I was thinkin maybe binding from full steering at hi speeds might have caused some gear issues? I also got some new(to me) wheels.. when I pulled my lightened v1's apart, I found some rausch creek in the foams and tires.. After cleaning and remounting, I came up with this.. |
11-08-2013, 09:30 PM | #45 |
It hasn't been but a couple weeks and maybe 3 runs.. another front gear grinding. So since the vvd rebuild kits were half price, I decided it might just be time for some bearing caps as well.. Anywho.. back to Another R&P... its still just another stick gear, the axial HD gears showed up the next say or so, just didn't change it out.. So now I have HD gear for the front and bearing caps.. that should take care of my gear problem.. MAYBE! see 2 of the 3 runs, were on 4s.. I run heavy equipment and our job site is a playground! So when I'm gearing down at the end of the day, I'm sloping ramps into dirt piles.. which range from 5 foot to 15 feet high.. nose dive at speed and it just doesn't take it to well, but its a BLAST! Now for a question.. should I gear up for more speed or go pro4? Then, do o want the 4000kv one or 3300kv? Maybe go with 3300 and gear it for crawlin and trail on 3s and wicked speed on 4s.. cause I want to watch it fly and I want to work on it cause it broke while I was having fun .. any suggestions!? Thanks BTW, I'll try and get pics off the "playground".. |
11-09-2013, 08:35 AM | #46 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Why not.... for sale section build
How's that steering setup with the 7950 and the dinky mount holding up for you? I have the same and burned up my servo in 5min. I just got my servo back from hitec, so I'm a little nervous running it again. I think it was an electronic problem, but not totally sure, so I'm a little gun shy. I was also thinking the 7950 maybe a little weak for a big wraith, so I'm curious if you have any heat issues with yours?
11-09-2013, 08:52 AM | #47 |
I have found the HD gears to last pretty good on high voltage 5-6s but the will eventually give up. I run 2100 kV crawl with 3s and go fast on 5-6 motor is a turnigy 1/8 scale putts out 2650 watts on 5s. I think the pro 3300 would be plenty fast on 4 is and still plenty smooth to crawl. I'm not a fan of stuff over 3300. Higher kV starts trading of heat for power and becomes less efficient |
11-09-2013, 09:05 AM | #48 | |
My wraith barely breaks 7lbs rtr. Lightened wheels and cut VP knuckle weights. So the 7950 has seemed to be plenty and without fail. Don't be gun shy, you can always send a hitec back to be fixed.. | |
11-26-2013, 07:41 PM | #49 |
Couple more for sale section/wanted ad finds showed up and weather has me off work early today and off tomm.. First up is a power plant that I couldn't turn the price down on.. Can't wait to see how the drive train holds up now! After seeing a couple builds done, I couldn't resist the look of this, so in came a new(to me) chassis.. And went to work.. (don't mind the dirt, I don't) After taking some screws out and making a couple cuts to each side.. The top came off.. Then the interior and "cleaned" up my cuts.. Then lined it up for a look see.. This is my stopping point and off for some "searches" .. well, for DAYS and a shat ton of diff searches, I have found two, yes 2, builds like this.. which neither of are horribly detailed.. which is ok.. I Know their is another one out there, a Orange paneled build, I believe by a vendor? That I can Not find and its driving me Nuts!!!! ANY ONE KNOW THE BUILD OR WHERE TO FIND IT!? PLEEAAASSEE HELP ME! I'm not the only one looking and searching, there are 2 of us trying to find these builds.. Thanks Ok, back to work.. I have some cleaning to do... Last edited by winnerone23; 11-26-2013 at 07:44 PM. |
11-27-2013, 02:05 AM | #50 |
Pebble Pounder Join Date: Apr 2013 Location: Thibodaux, LA
I loved watching the progress of your build. Can't wait to see more
11-27-2013, 01:33 PM | #51 |
12-24-2013, 01:42 AM | #52 |
Between work and lack of motivation at home, I haven't had much progress. Now that I got a few days off, is felt the urge to get busy. Well, since the wife wasn't having that, lol, I decided the Sexo was the next best thing.. I spent some time weighing my options of mounting it forward or further back and started drilling holes and running screws in. From there I looked at using the front exo braces bent to line up as a front support to the wraith rails. Then I looked at the front cross section on the wraith and how it mounted to the rails.. Cut, chop and drill it into place.. I used a 3/32 for the screw holes and a 13/64 for the female butt joint. I turned the front bumper mounts/supports around and cut, an drilled them as well. Next was the exo lid mount.. it all started coming together at this point. A little work with a sanding drum and fitment was a breeze.. Once I put it in place, I realized the 2 screw holes would lock it all in together. So I drilled 2 more holes.. Now if I had to do it again, I may not have turned the 2 wraith bumper mounts around, but knowing how I treat the thing and with a bigger power plant goin in. I'm sure all the support it can get is welcomed.. That's the middle and front end. Ill jump on the rear tomm.. |
12-24-2013, 02:45 AM | #53 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
Dude this truck looks like its to hell and back reliable. Wow!
12-24-2013, 11:00 PM | #54 |
Rigs been a blast to build, run and abuse! And.... Its prolly not goin to get any better, any time soon! B-) The 10t pinion was a little long. It was also solid at the end. So I drilled it out to sit farther down on the motor shaft. When that still wasn't enough, I cut a spacer.. And drilled a couple holes for air. Put it in to check everything out and wire lengths. Esc, bec, and Rx will go under the hood. More still to go.. was hoping to take it to families tomm, for a reason to Get Out! Lol.. oh well.. |
12-25-2013, 01:46 AM | #55 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
There are two of us in my local town here that have builds similar to this one. Eggbert from here on RCC put together both chassis' and fully built the other couple rigs I have seen like this. I recently purchased my chassis from him and will be doing a build on it soon. Your build is coming along nicely!
12-25-2013, 04:22 AM | #56 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
Here ya go Troy |
12-25-2013, 07:24 AM | #57 |
I heard that 1R3LAND hates green! Nice rigs fellas, hope to be part of the "cool kids" club soon!! |
12-25-2013, 07:54 AM | #58 |
12-25-2013, 12:37 PM | #59 |
Rock Crawler Join Date: Jun 2012 Location: jville
Liking the build and the camo keep it up
12-25-2013, 01:01 PM | #60 |
Thanks.. yeah the camo is the setup, for now. Good for back up.. I have some black exo panels coming. As well as a set of custom panels that need finished.. Last edited by winnerone23; 12-25-2013 at 01:23 PM. |
Why not.... for sale section build - Similar Threads | ||||
For Sale section....... | EdmontonTrader | Comments, Suggestions, and Help | 78 | 05-11-2015 07:34 AM |
Sale Section | Hemipower23 | Comments, Suggestions, and Help | 7 | 09-13-2010 12:38 PM |
Wanted section and for sale section | InFlames | Comments, Suggestions, and Help | 13 | 10-20-2008 09:12 AM |
4 sale section/wanted section ????? | stevew | Comments, Suggestions, and Help | 21 | 12-14-2006 06:38 PM |
Do any noobs in the wanted section read the 4 sale section? | Unimoger | Chit Chat | 11 | 01-24-2006 12:21 PM |
