04-23-2013, 08:53 AM | #1 |
Newbie Join Date: Mar 2013 Location: Dover
| Help
Hi all, I just took the Wraith out and she was running fine until she tipped over and rolled down a bank and now there is a clunking\clicking noise when she drives forwards or backwards. I have done a quick visual inspection and everything looks ok but I was wondering if anybody has any ideas what it can before before I start stripping it down. Any advice would be greatly appreciated thanks |
04-23-2013, 08:55 AM | #2 |
| Re: Help
Sorry if this post should have gone in the Newbie General section
04-23-2013, 08:55 AM | #3 |
| Re: Help
Does it have dog bones in the front axle? Make sure your CHubs and Knuckles are in place. |
04-23-2013, 08:59 AM | #4 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Help
Need... More... Data... Where is the noise coming from? Do all of the wheels 'drive'? Are your drive shafts still attached properly? |
04-23-2013, 09:16 AM | #5 |
| Re: Help
All the wheels drive and I cant seem to work out where the noise is coming from. Its a totally standard RTR Wraith as well
04-23-2013, 09:21 AM | #6 |
| Re: Help |
04-23-2013, 09:28 AM | #7 |
| Re: Help
You should check the transmission gears, one may have chipped. Just remove the drive shafts and and then run it to see if you hear the clicking. While the drive shafts are off, you can also turn the wheels and see if it's coming from one of the axles. |
04-23-2013, 09:34 AM | #8 |
| Re: Help Thanks I will give that a try
04-23-2013, 11:53 AM | #9 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Help
ON my RTR Wraiths bottom gear (The one that the driveshafts are connected to) the 3 screws that held the outputs to the gears were loose & made some intermittent noise until I got in there & loctited them down. Just a maybe consideration. |
04-23-2013, 06:31 PM | #10 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: Help
It could be as simple as a small pebble lodged somewhere. It happens to me often. Do let us know what you find however.
04-23-2013, 06:43 PM | #11 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
| X2, did that but with a rrp solid bottom gear, mad me sooo mad
04-23-2013, 06:46 PM | #12 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Re: Help
My pinion came loose the other day. Everything still ran the same but the clicking noise i heard was the pinion rubbing on the cover
04-25-2013, 07:57 AM | #13 |
| Re: Help
Thanks for all the replies I aint had chance to look at it because of work but I will be investigating it Saturday
04-26-2013, 10:54 PM | #14 |
Newbie Join Date: Mar 2013 Location: Nevada, shacked up in a tin shack
| Re: Help
Same thing happened here , turned out to be disbris in the pinion and spur gear. We cleanes it out an it b fine now .
