08-01-2013, 01:39 PM | #181 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I did the exact same thing. I'm still amazed at how damn tough the rig is. I still haven't serviced the transmission once!
08-01-2013, 02:35 PM | #182 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
08-01-2013, 08:46 PM | #183 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Been looking into wraith axles some and came across this thread. If a guy was so inclined could a 5x13x5 angular contact be shoe horned into the case? http://cad.sbn.de/ArticleDetails.asp...7105+MSS+2Z+VA |
08-01-2013, 09:33 PM | #184 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
There's enough meat in the case to machine the inner bearing seat for a 5x13. Not the outer though.
08-01-2013, 09:50 PM | #185 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
08-01-2013, 10:21 PM | #186 |
08-01-2013, 10:24 PM | #187 |
08-01-2013, 10:25 PM | #188 |
08-03-2013, 07:54 AM | #189 |
The thrust bearing held up great yesterday. |
08-03-2013, 08:50 PM | #190 |
Quarry Creeper Join Date: Aug 2011 Location: San Ramon
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread after taking mine apart and finding the bearings were fine, I said screw the bushings. BIG MISTAKE. the power my pro 4 3300 was pushing, the inner bearing blew out causing the pinion and ring gear to grind together. since that happened, I had to buy a new gear set and some traxxas bushing. the bushings are cheap. I just plan on checking to see if the bushings are wearing out. I,d rather them wear out instead of blow out. |
08-04-2013, 06:40 AM | #191 | |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
Either way, the next time your bushing wears out, try one of these: 5x11 Bearing 5x11x4.5 Thrust Bearing Bearing F5-11M | |
08-04-2013, 08:17 AM | #192 |
I am not going to let the bushings wear all the way out, which will save my r&p. But I will definitely try the thrust bearing. Thanks
08-04-2013, 11:48 AM | #193 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
I'm still a newbie but I come with a background in drag racing and vintage road racing along with heavy equipment and truck experience. I think part of the problem exists because the stock plastic housings don't have enough support. One example is in a drag car the tires try to drive around the housing. Causing the housing to become c shaped when that happens it opens the lash between the pinion and ring gear and if its bad enough it will destroy the r&p. To combat this you need to brace the housing which is usually in the form of a back brace. If you look at a wraith housing there isn't much in the way of bracing to keep area between the link mounts from moving front to rear. I'm not a huge fan of helical cut gears because they induce thrust when power is applied along with linear loads. In the case of a ring and pinion the pinion tries to crawl up or down on the ring gear add in the helical cut hd r&p from axial now your trying to shove the pinion out of the front of the housing. So now you have another force invloved. Even if you install beef tubes in the axle housing that does not help support the center section where the r&p is. I guess what I'm getting at is you can't just focus on the bearings themselve although they still need attention the whole axel assembly needs to be adressed for the forces that are applied to them. |
08-04-2013, 12:54 PM | #194 |
Tore into my axles today finally after the G6 a couple weeks ago. My bushing are still rock solid, the only noticeable wear I can see is on the out part of the outer bushing where my MIP hub has been rubbing. I have lost count of how much run time they have on them. Still not sure what the cause of the other guys having their's seize up is. At this point without seeing a housing redesign for different bearings I don't see a better alternative. Uploading pictures now. |
08-04-2013, 12:58 PM | #195 | |
That a great post and good info. I also agree that plastic housing can definitely cause failure. Like I have said before, once the stock housings give once they need to be replaced. They weaken over time and will deflect easier and easier each time. | |
08-04-2013, 12:59 PM | #196 |
Here is the only noticeable wear I can see. |
08-04-2013, 01:54 PM | #197 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
I'm currently setup with plastic housings because my pockets are not deep enough for the metal goodies, but I think the dinky servo mount can combat some of the axle house flexing. I'm running one front and rear. I'm not running rear stear, but have the mount anyways because it ties in both tube sides and a screw in the pumpkin. Metal housings are probably best, but for budget I think the dinky mount can prolong the life of a plastic housing. |
08-04-2013, 02:00 PM | #198 | |
08-04-2013, 02:02 PM | #199 |
08-04-2013, 02:14 PM | #200 | |
See those two flat spots? Wonder how they line up... Last edited by Harley; 08-04-2013 at 02:40 PM. | |
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
