04-26-2013, 09:59 PM | #21 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
04-26-2013, 10:00 PM | #22 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
04-28-2013, 08:20 PM | #23 |
Quarry Creeper Join Date: Dec 2010 Location: Gaffney
Any update on this Harley? I just blew up another bearing at the last comp.
04-28-2013, 08:30 PM | #24 |
Pebble Pounder Join Date: Dec 2012 Location: Fleming County
I just lost my rear ring gear because I hadn't inspected mine (3 months old). I been wanting a reason to order under drive/over drive gears anyway. Sent from my XT907 using Tapatalk 2 |
04-28-2013, 08:51 PM | #25 |
04-28-2013, 09:38 PM | #26 |
04-28-2013, 09:47 PM | #27 |
Sweet! Ready to see the fix
04-28-2013, 10:36 PM | #28 | |
Rock Stacker Join Date: Feb 2013 Location: Apache Junction
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
04-28-2013, 11:57 PM | #29 |
Newbie Join Date: Feb 2013 Location: Norway
Can't find TRA1243? But I can find TRA1675, which is supposed to be 11x5x4. Will they work, or are they a differend tolerance?
04-29-2013, 07:30 AM | #30 |
| Tolerance is in the dimensions. They should work. I'd wait to see what Harley is cooking up though. It'll probably be worth the wait.
04-30-2013, 02:53 AM | #31 |
Quarry Creeper Join Date: Oct 2012 Location: meriden
Ill be getting these as well....my rear axle ring gear doesnt like.me right now....
04-30-2013, 03:07 AM | #32 |
There all the same tolerance. Would cost to much have another assembly line for cheaper. Traxxass most likely buys these from across the pond I think this shows what part number I used Last edited by evan03; 04-30-2013 at 03:10 AM. |
05-02-2013, 03:39 PM | #33 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Any updates, Harley? Just a thought, would it be beneficial to run some of these bushings in any other locations (knuckles, ends of the axle housing) on a high powered rig? |
05-02-2013, 03:55 PM | #34 | |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Bearings can lose the balls at the time of failure increasing the play on the shaft dramatically. This increased play can & will damage gears. The pinion shaft with lots of power / speed burns bearings fast (sometimes so fast it damages other axle components before you notice the bearing) bushings slow this failure down so you can swap em out before any other damage occurs. If you have other spots that are burning bearings up faster than you like, bushings will give you tougher, longer lasting performance at the cost of more drag. I want bearings everywhere else personally. I am curious as well about Harley's "bushing up his sleeve" & what they are made of. Last edited by Dostradamas; 05-02-2013 at 03:58 PM. | |
05-02-2013, 04:00 PM | #35 | |
It makes no sense whatsoever for them to make them in house. | |
05-04-2013, 11:49 AM | #36 |
Did your mail ever run harley?
05-04-2013, 01:52 PM | #37 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Crap, I forgot to check. I'll go look. Edit: hasn't come today yet. Last edited by Harley; 05-04-2013 at 01:55 PM. |
05-04-2013, 02:49 PM | #38 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
I'm impatiently awaiting this news, I got 2 packs through a new set of traxxas bushings, I am running a mmp pro4 3300kv in my dmg koh #7 w over under gearing, I really dont go slow w it, didn't get all the way through pack 2 n the rear end started making "the noise " aaahhhh Sent from my SGH-T889 using Tapatalk 2 |
05-04-2013, 02:53 PM | #39 | |
05-04-2013, 03:40 PM | #40 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I proved that the hard way. He's right.
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
