Thread: AR60 Pinion Bushings vs Bearings vs Bushings Thread
Old 05-07-2013, 05:27 PM   #61
Originally Posted by Pabust View Post
If Axial is considering a replacement for the Wraith it should consider redesign the axles with bigger bearings and gears anticipating the possibility of using more powerful motors than the stock ones
Wouldn't look scale with larger bearings though.
TheScaleAddict is offline   Reply With Quote
Old 05-10-2013, 04:30 PM   #62
Default Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread
Any updates?
Goatsniper is offline   Reply With Quote
Old 05-10-2013, 04:37 PM   #63
The gears are not really too small. When shimmed properly and without deflection from blown bearings the gear sets hold a lot of power.
Calderwood is offline   Reply With Quote
Old 05-10-2013, 06:11 PM   #64
Originally Posted by Goatsniper View Post
Any updates?
Harley is currently testing some prototypes, just a matter of how well they hold up and if any changes need made.
Devil Inc is offline   Reply With Quote
Old 05-10-2013, 06:37 PM   #65
Need another tester?
Old 05-10-2013, 07:17 PM   #66
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
I have put 2.5 hours through them so far. No difference wear to speak of. I have documented the install and put it on youtube. I will keep updating on the wear and see how long they last. With what we were assuming before, these should last at least 10 times as long but that has yet to be proven. I can get about an hour of driving in per night on these. Tomorrow I am going to a full size event and will try and put some runtime on them again.
So far so good.
Here is the YouTube channel, subscribe for fawks sake and you would have already had this info!
HarleyDesignsInc - YouTube
Harley is offline   Reply With Quote
Old 05-10-2013, 07:24 PM   #67
Originally Posted by Harley View Post
The over under gearing is a terrible combo with a rig that is going to have speed. You are multiplying the stress in the gears by adding the additional drag. You should be running the same ratio front and rear to keep the axles alive with pro4 type power.
Glad I saw that before I ordered the overdrive for the front axle! My bearings failed and destroyed my rear gears (pro4 power) so I under drove the rear. Looks like I am gonna under drive the front too :thumbup:
Sent from my fone uzeing spelchek.
gbaileyo7 is offline   Reply With Quote
Old 05-10-2013, 07:24 PM   #68
Or just look on your facebook too!! :P
ZippoMan is offline   Reply With Quote
Old 05-14-2013, 01:00 PM   #69
I will not be the one selling these, you'll all know where to get them soon enough.
Hmmm.... new offering from VP perhaps?
BodiBuilt is offline   Reply With Quote
Old 05-14-2013, 01:03 PM   #70
20K Club
Harley's Avatar
I've got maybe 8 hours of run time on them so far and they are still slop free. I wasn't getting that out of my old ones before they were wasted. Not sure how far I am going to keep testing before they are fine with giving them the thumbs up.
Old 05-14-2013, 01:04 PM   #71
Josh, they need more testers. Seriously... I nominate myself. I figure I deserve it, since I started this thread, and I have a bushing shredding rig.
Old 05-14-2013, 01:15 PM   #72
Mike Pham just put up some "spy photo's" over in the Scx10 forum... see post #193 for a sneak peek
Old 05-14-2013, 01:33 PM   #73
Originally Posted by Dostradamas View Post
Copper Alloy No. C86300?
Check out that hardness
C86300 Manganese Bronze - SAE 430 B
Bam! Spice weasel!
Thats exactly what I thought.
Dostradamas is offline   Reply With Quote
Old 05-14-2013, 01:54 PM   #74
So far so good.
Why no comparison between the two? I'd like to see how tight the tollerance is between them and a brand new traxxas bushing. Part of a long lasting part in this application is to have the tightest tollerance to begin with. Also, are they so hard that we will start seeing pinion shaft wear?
05Fronty4x is offline   Reply With Quote
Old 05-14-2013, 02:25 PM   #75
With a 225 Brinell hardness I suspect the pinion shaft will wear more than the bushing.
Still waiting for VP to announce so I can get a confirm on this material but I have heard nothing so far to the negative & that looks like the stuff to me.
Hardened pinion shafts next?
Old 05-14-2013, 03:36 PM   #76
It's official, we're changing your name to Iron Man. You know WAY too much about metals.
So.... Is this softer than Axial's hardened pinion shafts? (from the upgraded HD ring and pinion sets)
Old 05-14-2013, 03:43 PM   #77
Soon please. I blew a bearing Sunday.
I also nominate myself to be a tester.
DRTMI is offline   Reply With Quote
Old 05-14-2013, 03:54 PM   #78
20K Club
Harley's Avatar
I just never thought to grab new Traxxas bushings. They fit nice and tight when new as well as I am sure most people will agree with. That doesn't have much to do with the reason they wear out.
Old 05-14-2013, 03:58 PM   #79
20K Club
Harley's Avatar
You started a spin-off thread of a topic in the bulletproof thread. No soup for you!
We've got more hours to run on these and I'll talk with them again this week.
Old 05-14-2013, 04:00 PM   #80
20K Club
Harley's Avatar
The Axial shafts are hardened I believe, although I am not sure as to what value.
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads
Bearings vs. Bushings Lentsnh2012 Axial Wraith 47 11-23-2013 09:55 AM
Bushings>Bearings sundayface Axial SCX-10 7 02-29-2012 09:40 AM
bearings or bushings ??? 48machinerulz Tamiya TLT Crawlers 4 03-31-2007 02:28 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
