06-11-2013, 12:43 PM | #101 | |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
06-26-2013, 03:52 PM | #102 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Any updates on these guys?
06-27-2013, 01:45 PM | #103 | |
Quarry Creeper Join Date: Mar 2011 Location: over there...
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote: | |
06-27-2013, 01:47 PM | #104 |
My bad double post Last edited by bronc4now; 06-27-2013 at 01:50 PM. |
06-27-2013, 01:51 PM | #105 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
06-27-2013, 03:32 PM | #106 |
I've seen all the new goodies they've been rolling out lately. And I am trying to be patient, just gettting tired of pulling everything apart to check and replace the TRX bushings.
06-27-2013, 03:40 PM | #107 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I hear ya, that was how I felt too. I'm told they'll be getting to them. They have some more cool stuff coming this week I believe.
06-27-2013, 05:31 PM | #108 |
I say someone should come out with a better bearing so we don't have to compromise with bushings.. Roller pin bearings ! Make it happen or a axle that can fit a bigger bearing. that will be the next thing I bet..o but then there cost forgot about that.. |
06-27-2013, 05:43 PM | #109 | |
Sounds expensive for a bearing that small, I'm down with using bushings. If you redesign the housing, it will lose a lot of the scale realism that it currently has. Might be able to make it so a larger bearing could be used on the inside. | |
06-27-2013, 06:23 PM | #110 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I kinda wonder why VP didn't use at least a 5x13 or even a 5x14 bearing for their axle housings. Surely a 5x13 would hold up to the abuse we put them through.
06-28-2013, 07:53 AM | #111 | |
Also, most people have zero issues. There is a small part (big power users) of a portion (Wraith owners) of a small niche (Crawling) in RC that have this issue. Making the rest of the people in the hobby buy bigger bearings or deal with less ideal scale proportions just doesn't sound like a great business decision | |
06-28-2013, 10:07 AM | #112 |
Why are you guys resistant to bushings?
06-28-2013, 11:02 AM | #113 |
06-28-2013, 11:35 AM | #114 |
06-28-2013, 11:53 AM | #115 |
06-28-2013, 11:56 AM | #116 |
Bearings are easier for me to get than bushings....and I've had no problems with the bearings in my wraith.
06-28-2013, 12:03 PM | #117 |
06-28-2013, 12:27 PM | #118 |
06-28-2013, 12:38 PM | #119 |
06-28-2013, 12:54 PM | #120 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
if theese things can rust some eezox would help. its a gun lube that goes on and drys and is one of the best things I've seen for protecting metal from elemental exposure. it also provides some lubrication properties after its dried. it comes in a spray can (way way more then you need comes out) and a needle dropper which is much better.
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
