06-28-2013, 01:33 PM | #121 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread
they can keep their "scale" looks on the outside with a scx10 outer wheel bearing as its 1mm wider, then on the inside they can go with a larger bearing and keep it fairly well hidden.
07-02-2013, 06:51 PM | #122 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
i just want to make this clear for my self, what i believe your saying is the HPI bushings are better then the traxxas bushings? i am going to install the roc 412 3100kv in my wraith and i dont want a bearing to fail.
07-02-2013, 11:02 PM | #123 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread If you get the ones I noted to get in the initial post, they are indeed harder, and therefore, 'better' for the application than the Traxxas bushings. However, the SECOND the VP bushings hit the market, they will be MUCH, MUCH, MUCH, better than the HPI bushings.
07-02-2013, 11:12 PM | #124 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Yeah...... Not so much Mr. Foot In Mouth. The bearings in question are very small bearings. To get the bearings that small, you have to use, wait for it.... less material. Less material = weakness. If I were to put bearings in Fiona, she'd demolish them in a VERY efficient manner. If your wraith has real intestinal fortitude, those bearings are worthless at the pinion. That's all there is to it. Bushings are the ONLY way to go for the few of us who build wraiths as I, Harley, and a very select few others do. (comparatively to the whole RC user base) Here's Fiona getting a little bit frisky... Funny thing is, that isn't even full throttle. I was searching for 'just right' to get her to land on all four. She's a wheel lifter on the straits, which is impressive, given that she is FAR from being a lightweight. |
07-03-2013, 06:34 AM | #125 | |
Quarry Creeper Join Date: Mar 2011 Location: over there...
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
I'll see how long they last ccompared to a bearing.. | |
07-03-2013, 06:43 AM | #126 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Those are the 'softer' HPI bearings. They won't last as long as the others. Really, it depends on your motor/esc/battery combination. What are you running?
07-03-2013, 07:07 AM | #127 |
3800kv 4pole revtech...but only 2s lipo for now..
07-03-2013, 07:44 AM | #128 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
07-23-2013, 02:22 PM | #129 |
Newbie Join Date: Feb 2005 Location: N/A
Any updates on the Vanquish Products bushing?!
07-23-2013, 03:19 PM | #130 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
More data for the great bearing debate. http://www.skf.com/files/099926.pdf Bearing failure pdf by SKF (huge world supplier of bearings) Last edited by Dostradamas; 07-23-2013 at 03:50 PM. |
07-24-2013, 10:19 AM | #131 | ||
I guess some people are just lucky... Quote:
07-24-2013, 10:28 AM | #132 |
I guess a pro4, 3s, and summit trans isn't enough fortitude. |
07-24-2013, 10:31 AM | #133 |
07-24-2013, 05:49 PM | #134 |
While I don't rapidly disintegrate the pinion bearings in my Wraith, they certainly do wear out faster than I'd like. Someone casually mentioned a mod to place a larger 3rd pinion bearing inside the axle housing. Are their any specifics on this such as bearing size or how to retain it in the housing? I know the HD gears do have a spot on the pinion gear that seems like it would easily accept a bearing, but I have no idea how the housing would accept the outside of the bearing. Any idea's? I feel that adding a 3rd bearing would extend the lifespan of the other, smaller, pinion bearings. I only think of this because I know that my Wraith doesn't munch trans output bearings as fast as my SCX and AX-10. I attribute this to the very large 3rd bearing on the output shaft and thought that the same idea could be benificial for the pinion gears. |
07-26-2013, 06:38 AM | #135 |
07-26-2013, 09:05 AM | #136 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
I'm wondering if has to do more with what axle housings you are running. In my wife's wraith and in mine we are both running Pro4 3300, RX8, 3 cell lipos, with AX2 two speed transmissions. This past G6 series, I think 7 events, I went through 2 sets of Fast Eddie bearings and one set of gears. Mrs rig, still on original FE bearings. The only difference I'm running RC4WD aluminum housings and she is running stock housings with VP goodies. I do tend to drive quite a bit harder though. Needless to say, I can't wait for these VP bushings to be released. |
07-26-2013, 11:37 AM | #137 |
I think this whole situation only comes up when you have lots of power & too much pinion angle. The bearings wear because of side load not because they spin too fast. There is as well the factor of pushing the limits of the components. If you need multiple sets of bearings & gears to complete an event the course is abusing the rigs. When will someone just start making $500 axles with all this wear & tear covered. Hardened steel axle cases, chrome moly gears, more than hobby grade bearings etc. Obviously price is no object, finishing is. Bushings are merely helping the symptom without addressing the real problem Last edited by Dostradamas; 07-26-2013 at 11:45 AM. |
07-26-2013, 11:44 AM | #138 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I didn't think anyone was talking about the bearings spinning to fast but I may have missed it. It's certainly not the case. The upper trans bearings don't suffer the same fate and they spin much faster. The simple fact is that the bearings were never made to handle the thrust load that we place on them.
07-26-2013, 11:49 AM | #139 |
07-26-2013, 11:49 AM | #140 | |
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
