07-26-2013, 11:52 AM | #141 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
07-26-2013, 11:58 AM | #142 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Ah I see what you mean. The center is trying to push out & the balls get deformed quickly. Axle housing design. |
07-26-2013, 01:33 PM | #143 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
How about a spacer inbetween the inner and outer bearing to help push the force onto both bearings. I forgot whats inbetween and if it could even fit though! Scratch that, the outer bearing would need to be retained from pushing out of the housing Last edited by Cableman; 07-26-2013 at 01:36 PM. |
07-26-2013, 02:01 PM | #144 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Too bad they don't make tapered roller bearings that small. They would handle the thrust load better than a ball bearing. Almost: http://www.ntn.co.jp/english/news/ne...s20061219.html $$: http://www.vxb.com/page/bearings/PROD/Kit7405 Last edited by frdtrkguy; 07-26-2013 at 02:20 PM. |
07-26-2013, 02:24 PM | #145 | |
07-26-2013, 02:33 PM | #146 | |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
That would be a good project for a vendor. They could take axial HD gear sets and turn 4.5mm of the pinion shaft shoulder down to 5mm and sell the kit with the trust bearing. Using this bearing: 2 Thrust Bearing 5x11x4.5 Grooved Washers Miniature Thrust Bearings: VXB.com Ball Bearings If it would fit, I think it would definitely fix the problem since the inner thrust bearing washer would be pushing against the outer race of the inner pinion bearing. Hell, I may try it myself.. Last edited by frdtrkguy; 07-26-2013 at 02:38 PM. | |
07-26-2013, 08:04 PM | #147 | |
07-26-2013, 08:20 PM | #148 |
McMaster sells almost what you guys need: McMaster-Carr 5x12x4 Boca also has some: http://www.bocabearings.com/bearing-...hrust-bearings http://www.bocabearings.com/bearing-...el-ball-series And Avid has some that are WAY cheaper: http://avidrc.com/product/13/thrust-bearings/ Last edited by JeremyH; 07-26-2013 at 08:28 PM. |
07-26-2013, 08:36 PM | #149 | |
Hopefully these can help the "select few" with issues. | |
07-30-2013, 05:36 PM | #150 |
07-30-2013, 05:43 PM | #151 |
Jeremy, those are what we were talking about when we were saying you would need to mod the pinion. You can't just replace one of the existing bearings since the thrust bearings you linked to cant handle side loads. That's where the taper bearings come in. They can be loaded from either direction.
07-30-2013, 05:47 PM | #152 |
There are two bearings around that pinion. I put the thrust bearing on the gear side with the load piece closest to the gears. I left the outer bearing the same. This should have both axial and side loads covered. However, I guess we'll never know.....as I'm not an "select few" builder...... |
07-30-2013, 05:50 PM | #153 |
Did ya turn down the od to make room for the thrust bearing? And it clears the ring gear?
07-30-2013, 05:50 PM | #154 | |
07-30-2013, 05:52 PM | #155 |
I turned down nothing. It clears the ring gear just fine. The dimensions of this bearing are the same as the stock bearing except it is 0.5mm thicker, which was just fine as my pinion had some play in it anyway.......key word, "had". More info: Jeremy's RCC Giveaway Wraith Kit Build |
07-30-2013, 05:56 PM | #156 | |
He only has the outer stock bearing. | |
07-30-2013, 05:58 PM | #157 |
Oh, I see. My idea was to use both of the stock pinion bearings and the thrust bearing. I'm interested to see how it holds up |
07-30-2013, 06:00 PM | #158 |
07-30-2013, 06:03 PM | #159 |
07-30-2013, 06:03 PM | #160 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread I am not so sure that would work. Even if you removed that shoulder on the pinion, the outer race (on the housing) is not deep enough for both to fit.
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
