07-30-2013, 06:04 PM | #161 |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread |
07-30-2013, 06:06 PM | #162 |
07-30-2013, 06:07 PM | #163 |
07-30-2013, 06:12 PM | #164 |
07-30-2013, 06:12 PM | #165 |
Jeremy ran his wraith for 2 years on stock bearings with no issues. So if he puts these bearings in and they don't fail how would that make these bearings any better?
07-30-2013, 06:13 PM | #166 |
07-31-2013, 09:28 AM | #167 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
I don't think that's going to work. The inner pinion bearing sees as much if not more radial load from the pinion head trying to crawl it's way up the ring gear as it does thrust load from the ring gear pushing the pinion head away. Running a thrust bearing only for the inner bearing will ware (radially) into the axle housing. If only we could get axle housing manufacturers to machine the inner bearing location for a 5x13x4mm inner bearing... A more HD inner bearing would last much longer.
07-31-2013, 09:31 AM | #168 |
07-31-2013, 09:38 AM | #169 |
Because the bushing shouldn't spin in the housing. The inner race (the one against the pinion head) on the thrust bearing will. That inner race will be half way "in" the axle housing seat.
07-31-2013, 09:40 AM | #170 |
What makes you think that either side of the bearing will spin any more than a bushing will?
07-31-2013, 09:45 AM | #171 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
I run the same Bearings as the day i put my truck together besides one tranny bearing. I run stupid power, and drive crazy. I'm still on stock ring and pinions cause i shimmer them just right to start with, and keep them bathed in grease. I get a new Power plant today, so lets see how these bearings hold up. You can ask jeremy how i drive |
07-31-2013, 09:51 AM | #172 | |
| Re: AR60 Pinion Bushings vs Bearings vs Bushings Thread Quote:
The thrust bearing in post #150 has 3 pieces. An inner race (against the pinion head) that will spin when a rotating thrust load is applied to it. The ball and cage assembly (that spins at half the speed of the inner race). And the outer race that stays stationary against the mount surface (axle housing). Last edited by 65BAJA; 07-31-2013 at 09:54 AM. | |
07-31-2013, 10:01 AM | #173 | |
Anytime you put a thrust load on an object, obviously there is the possibility for that object to spin, but I don't see how that will be any different with a bushing. | |
07-31-2013, 10:28 AM | #174 |
How tall (thick) is the thrust bearing? How deep is the seat it sits in? My thought was that if the seat is 4mm deep and the bearing is 4.5mm thick then the race that spinns with the pinion head would be, at least partially, sunk into the seat of the axle housing. This spinning race would ware the housing. The bushings even with thrust loads on them shouldn't spin in the seat.
07-31-2013, 10:45 AM | #175 |
It is 4.5mm tall. Not sure on the depth of the housing race. Even if it's only partially inside the housing, it still shouldn't spin. You could very well be right about this, I am just trying this to satisfy my own curiosity... |
08-01-2013, 12:59 PM | #176 |
Baja, it seems that we were both wrong about how these bearings would operate in this application. I just tore apart the diff and inspected everything. The race with the smallest ID that I placed closest to the gears, spins freely in the housing....while the race closest to the second bearing sits still. Also, the outer race sits (what appears) flush with the lip of the housing. I am not sure if the stock housing is beveled slightly or not (this housing is fairly new), but it gives some room for that inner race. Here are a few pics: I marked a line on the inner race (closest to the pinion gears) and was hoping to see it move as I spin, but it did not.....not even when I pressed down on the pinion as hard as I could and spun it. Now, I know that me pressing on the pinion is nothing even close to the force that will be exerted when power is applied to the truck and it experiences torque changes, but my thinking was solidified when I saw this. I also spun the inner race around the pinion and pushed it up against the shoulder and I dont see them spinning as one. Even if they (inner race and pinion) do spin as one, the race should just spin on the bearings leaving that outer race to sit still. I cant think of any way to test what happens in the diff without building it and running it. So I plan to place the mark on the race vertically, run it and then take it apart again to see if it has moved. Last edited by JeremyH; 08-01-2013 at 01:02 PM. |
08-01-2013, 01:09 PM | #177 | |
It's way cool that you are experimenting with it. I'm going to try some different setups out too. This will all result in good tech wether any of it works or not. | |
08-01-2013, 01:13 PM | #178 |
It's possible. But that thrust bearing is supporting the pinion as well, just not as much as a regular bearing (the race that sits still is only about 1/3 the width of a race on a regular bearing)...
08-01-2013, 01:16 PM | #179 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Man I beat the crap out of mine and have only slightly bruised one pinion bearing (r). Front is original. Is is the Al axles keeping things aligned? J |
08-01-2013, 01:21 PM | #180 |
Joel, yeah, same here. When I pulled out the stock bearing the other night, it was still in good shape. Not as smooth as a brand new bearing, but I wouldnt hesitate to put it back in there (in fact, I kept it to reuse ). |
AR60 Pinion Bushings vs Bearings vs Bushings Thread - Similar Threads | ||||
Bearings vs. Bushings | Lentsnh2012 | Axial Wraith | 47 | 11-23-2013 09:55 AM |
Bushings>Bearings | sundayface | Axial SCX-10 | 7 | 02-29-2012 09:40 AM |
bearings or bushings ??? | 48machinerulz | Tamiya TLT Crawlers | 4 | 03-31-2007 02:28 PM |
