05-10-2013, 04:48 PM | #1 |
Newbie Join Date: May 2013 Location: Guelph, Ontario
| Make Wraith More Crawl-able?
Hey guys, new here. I was just wondering what I can do to make my wraith more crawl-able. Cheap mods or upgrades. Not wanting to spend a lot of hoopla to get it there :P Thanks guys. |
05-10-2013, 05:03 PM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Up North
You will need to throw down some green....this hobby is not good on wallets and CC....probably even marriages....lol
05-10-2013, 05:18 PM | #4 |
| Re: Make Wraith More Crawl-able?
Good bead lock rims. Sticky tires. Lower the ride height. Get weight bias forward(Move battery location to front most important). Good solid suspension and steering links. Strong reliable servo. Quality brushed motor. Holmes BRXL esc. Steel tranny gears. All steel drive shafts. That's a good start. I've done all that and more over time and I love the capability of mine. It's more fun on the rocks than my AX-10 ever was. Your wallet won't feel so empty if you don't do it all at once. |
05-10-2013, 05:56 PM | #5 |
Pebble Pounder Join Date: Jul 2012 Location: Chattown
Lower your ride height down by flipping the shock mounts = free. Change to a 87 tooth spur = $8 Cut and groove the ripsaw tires = free. Move your battery to the front = free. This will make it a very capable crawler. |
05-10-2013, 06:00 PM | #6 |
Thanks wild man! Cutting the tires...is that removing ever other tread? And would a 90 tooth be good? I realize I'll have to drop some coin into this. I just got a job so hopefully the steady income won't make me notice my wallet shrinking! |
05-10-2013, 06:34 PM | #7 | |
| Re: Make Wraith More Crawl-able? Quote:
Here is how I cut my tires. Last edited by wildmanMG; 05-10-2013 at 06:42 PM. Reason: pic | |
05-10-2013, 06:53 PM | #8 |
What would I use to cut that accurately? Just a small cut off wheel on a dremel?
05-10-2013, 07:02 PM | #9 |
I used lexan scissors.
05-10-2013, 07:14 PM | #10 |
I found a pair of 3$ rose bush/tree pruners to be the best, easy on ur hand most of all.
05-10-2013, 07:17 PM | #11 |
Rock Stacker Join Date: Feb 2013 Location: S. AZ
I had the same issue. I parts it out ;) MSE mobile |
05-12-2013, 12:35 PM | #12 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
Free stuff I did for pure crawling: Cut my Ripsaws. The white dot/R35 Ripsaw are WAY better than the RTR versions. I got lucky with my used Wraith. It came with them. I just used a small set of wire cutters. Doesnt have to be pretty. I also shaved my sidewalls with a grinder. Easy. Once again, doesnt have to be pretty. I made a boo-bbo on one. Used some liquid electriacl tape to patch the hole. I flipped my front and rear lower shock mounts. I flipped the upper, rear shock mount. Remove interior and seats. I traded mine for a set of HB Sedonas which I now run with Crawler Innovations foams Cheap stuff: Soft springs. 10wt shock oil. 87/14 gears. Or go for 90/14 I just got a holmes Hobby Torquemaster Sport. 45T. Only cost $40 It's awesome. BEST mod I've done for crawling improvement was a set of XR10 Wheels. The internal weights and the option for bullet weights will instantly make your Wraith do stuff it never could before. I still run my battery in the rear and this thing climbs like a MF! Last edited by Bansh88; 05-12-2013 at 12:39 PM. |
05-12-2013, 01:16 PM | #13 |
Thanks Bansh! VERY helpful. |
05-12-2013, 01:25 PM | #14 |
Good tires and a set of knuckle weights.
Make Wraith More Crawl-able? - Similar Threads | ||||
wanting to make a scale snorkel for my wraith | wrathofthwraith91 | Axial Wraith | 3 | 03-29-2013 01:39 PM |
Make your Wraith go 10MPH faster.... | GravelDuster | Axial Wraith | 19 | 07-15-2012 02:15 AM |
2012 Colorado Crawl-Off and make-up comp 6/1-3/12 | 666 | Colorado | 58 | 06-05-2012 09:41 AM |
WRAITH PANEL IDEA! - What can I do to make this work? | J.DUKE | Paint and Body | 1 | 03-02-2012 08:30 PM |
