05-27-2013, 08:12 AM | #1 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Can I replace the dig trans case with a regular case?
I want to use the dig case from my wraith on my Ridgecrest crawler project. If I swap the dig case for a standard non dig shortened case, will I have issues with my driveshafts? will have have to relocate the transmission back to compensate? Thanks for your help on this one. |
05-27-2013, 08:45 AM | #2 |
| Re: Can I replace the dig trans case with a regular case?
If you move the trans back then your motor will hit the link mount. Supershafty sells an extended output.
05-27-2013, 08:41 PM | #3 |
Suppose I could grind the skid plate if push comes to shove. Hhhmmmm, maybe ill just buy another dig case
05-28-2013, 09:03 AM | #4 |
Pebble Pounder Join Date: Aug 2011 Location: Aiken
Or you can use one of these for the rear output to extend it so it will be around the same length as before. Crawler Innovations Long Output |
05-28-2013, 09:16 AM | #5 |
A new dig case is 10$ so instead of taking it from my wraith, ill just buy a new case for my project. Thanks for your input all. |
Can I replace the dig trans case with a regular case? - Similar Threads | ||||
VP Trans Case Help | GravelDuster | Axial Wraith | 3 | 08-30-2012 09:30 PM |
VP Trans case | Cleaner | Axial AX-10 Scorpion | 11 | 11-26-2010 01:27 PM |
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case | Crawln Coles | Scale Accessories | 215 | 02-02-2009 03:31 PM |
stock ax10 trans case,h r dig ,h r aluminum gears? | jd267 | Axial AX-10 Scorpion | 0 | 01-10-2009 05:40 PM |
