06-01-2013, 03:46 PM | #1 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
| RRP failed me!
I was doin some light bashing with my wraith. I have a tekin sc4x 7.5t in it(love this motor!), anyways i was jumping a little ramp and next thing i knew i didnt have front wheel drive. I picked my wraith up and saw my mip driveshaft hanging and my upper driveshaft spline gone. I looked arounf the parking lot and found it with the pin still in it. This is what i found... |
06-01-2013, 05:00 PM | #2 |
Pebble Pounder Join Date: Jul 2012 Location: Chattown
| Re: RRP failed me!
I've see this happen before. The main reason I still run the stock drive shafts. I rather them break than my RRP one piece bottom gear.
06-01-2013, 05:34 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: RRP failed me!
Yeah I have heard the same story!! I hope mine lasts a little longer. I am using only 2S with a Tekin RS and Redline 13.5T motor.
06-01-2013, 05:44 PM | #4 |
06-01-2013, 05:46 PM | #5 |
I'm running a Pro4 3300kv. I haven't had mine break yet. I would try to contact RRP and see if they might help you out. Sent from the foot hills of Tennessee. |
06-01-2013, 06:18 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: RRP failed me!
Got a buddy that has twisted and bent 2 of these. One of them just driving in the yard. I don't think RRP will be wanting to replace it but keep on them and they should. I know they didn't want to replace his.
06-01-2013, 08:44 PM | #7 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: RRP failed me!
Or contact supershafty.com & get... Chromoly Extended outputs up to 8mm!!! Broke a couple of those just like the pic shown. This trans is nearly bulletproof! |
06-01-2013, 09:36 PM | #8 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
Just imagine what would have happened to your stock diff... LOL
06-01-2013, 10:16 PM | #9 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: RRP failed me! |
06-02-2013, 06:51 PM | #10 |
Just broke the rear. Thats a 2 pole brushless motor doing that! I was driving around in my loving room not even going fast. Just putting around and the rear shaft fell out.
06-02-2013, 07:54 PM | #11 |
| Re: RRP failed me!
I piece bottom gears, meh. Get a good quality steel gear and use a better output like SuperShafty or stay with a stock output. |
06-02-2013, 09:45 PM | #12 |
06-02-2013, 09:50 PM | #13 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: RRP failed me!
SuperShafty or the outputs from Crawler Innovation. I have the outputs from Crawler Innovations put up against a 6900kv Castle 4 pole motor and a Mamba Max Pro and MIP driveshafts. My Wraith probably weighs about 8bs with a 5000mah 40C 2S lipo in it. There's no telling how many times I've "bumped" a rock trail and doing a full throttle landing. |
06-02-2013, 10:02 PM | #14 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Why would you want to run Any output shaft with a hole in it? I know it was made that way, but anytime you put a 2.8mm hole in a 5mm shaft your asking for trouble. Just get the Scx10 Rpp outdrive without the hole, locktite a 3mm setscrew in there and never worry about it again. Just my $0.02........
06-02-2013, 10:09 PM | #15 | |
| Re: RRP failed me! Quote:
It might sound like I've had wayyyyy too many tonight (I have had a few) | |
06-02-2013, 10:16 PM | #16 | |
Beefy = better I like a through hole design, no chance of driveshafts spinning or popping. | |
07-27-2013, 06:52 PM | #17 |
I got it back sometime ago. But it looked like to me, and alex chen that they had welded the ended back, re lathed it, and drilled back
07-27-2013, 07:55 PM | #18 |
07-27-2013, 08:23 PM | #19 |
When i get done repairing a busted water pipe. I should be getting my pro4 HD Tuesday, or wendsday. I'll have my tranny out for that
07-30-2013, 02:05 PM | #20 |
RRP failed me! - Similar Threads | ||||
failed step | gionata78 | Videos! | 0 | 02-14-2013 05:59 AM |
Failed Picture Archive! | MICHIGAN CRAWLER | Micro Scale Rigs | 5 | 10-13-2011 09:52 PM |
Failed Tank Loading | RANOVRU | Chit Chat | 2 | 03-09-2011 10:16 AM |
Moped failed on a 11.1v 2200LiPo!!! | TheHeadHunter | Electronics | 32 | 04-08-2009 08:17 PM |
