Thread: G Made Piggy backs
Old 06-09-2013, 11:47 AM   #1
Default G Made Piggy backs
Anyone have a set of these on their wraith? i hear nothing but good things about them.
imcochrane is offline   Reply With Quote
Old 06-09-2013, 02:16 PM   #2
Default Re: G Made Piggy backs
I have them on my wraith. They are pretty stiff if you build them to the directions so I put in the 4 hole pistons and some 20wt oil to help loosen them up a bit.
Rjohn929 is offline   Reply With Quote
Old 06-09-2013, 02:30 PM   #3
ok thanks, i this is not a primary crawling rig, just ordered a 2 speed tranny, going to build it for speed, and crawling, so they might be the right shock for me
Old 06-09-2013, 02:50 PM   #4
I have them with green springs, soft, and IMHO work great with my rig's weight - I removed the red stop rubber bumper, increased the ride of the shocks by unscrewing the uniball and gained 3 more mm ride! Smooth and flexy!
- Slim -
slimfire is offline   Reply With Quote
Old 06-09-2013, 02:53 PM   #5
I used the stock springs due to the weight of my Wriath but yeah, they are a pretty nice shock. I'm actually thinking of getting some FT SC10 4x4 big bore rear shocks to try next. They might be the smoothest shock I have ever used and have not leaked a drop in my SC10.
Old 06-09-2013, 05:50 PM   #6
I have them on my Wraith and will be removing the piggy back portion because you unable to adjust top shock mount position without them binding on the frame.
Great shocks they don't leak and the adjustment does function well.
foxmecx is offline   Reply With Quote
Old 06-09-2013, 07:05 PM   #7
I also have them and the top mount is very loose. Ball seem too small for the top mount hole. Like foxmecx the piggyback bind on the frame especially in the rear.
skeelo is offline   Reply With Quote
Old 06-09-2013, 09:31 PM   #8
just a suggestion, rotate your shocks 180 degrees so the reservoir is in the front or forward facing .I have them on my Wraith and only crawl with it and love them!
redneckwraith is offline   Reply With Quote
Old 06-10-2013, 12:17 AM   #9
I also had the issue with the reservoir colliding with something ... However I always found a hole/position/side to accommodate them w/o having to remove the reservoir which works simply great in terms of tuning the shocks' response which is the added value of these shocks IMHO!
- slim -
Old 06-10-2013, 09:44 AM   #10
Crawlster's Avatar
they work good for me
Crawlster is offline   Reply With Quote
G Made Piggy backs - Similar Threads
how many of you have gmade piggy backs? evan03 Axial Wraith 1 02-28-2013 04:03 AM
