Thread: 5mm hex hub extenders
Old 06-12-2013, 06:33 PM   #1
Default 5mm hex hub extenders
hey guys, new to the forum but have a question that I know someone can answer. I purchased 5mm hub extenders and there isn't enough thread on the axle shaft to get the lug nut on??? let me know what I have to do. seems to be a lot of manufactures out there selling parts without letting you know what else is needed to complete. thx
clb59 is offline   Reply With Quote
Old 06-12-2013, 06:58 PM   #2
Default Re: 5mm hex hub extenders
Look for a Barrel Nut.
JeremyH is offline   Reply With Quote
Old 06-12-2013, 07:04 PM   #3
thank you......I guess I was not aware they sold separately. I need to measure and order then?
5mm hex hub extenders - Similar Threads
hub extenders for wider front stance snail78 RC4WD Bully 5 03-04-2011 08:15 AM
17mm wheel hub for 5mm axle? ElectronJunk Axial AX-10 Scorpion 4 01-03-2009 09:43 AM
12 mm hex extenders? CrawlnSlow Tires and Wheels 0 01-22-2005 10:02 PM
