10-18-2013, 07:57 AM | #481 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build
Does the Corrosion X dry, or is it just a thick oil?
10-18-2013, 08:09 AM | #482 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build It never truley dries. The original ROC 412 I did 5 or 6 months ago still looks really good even after a lot of water. If I was doing a lot of water running without the sealant I would reapply the CorrosionX every 6 months probably. However with the sealant like I did on this one I probably wont worry about it at all.
10-18-2013, 08:34 AM | #483 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Amazing!!! Guess I will be adding corrosion x to the list. So when you say few coats just dip few times? I have learned so much from this thread alone, Thanx Harley!!! |
10-18-2013, 08:42 AM | #484 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Have you ever tried internal springs in the Powerstrokes? I really like them as well but the spring rates just seam high
10-18-2013, 08:48 AM | #485 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
10-18-2013, 08:51 AM | #486 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build |
10-18-2013, 08:59 AM | #487 | |
Stock setup rear is 2.5(p)/4.7(s) You can go as low as: 1.8(p)/3.5(s) front 1.5(p)/2.6(s) rear P= primary S= secondary Spring rates are in lbs/in. | |
10-18-2013, 10:29 AM | #488 |
10-18-2013, 10:42 AM | #489 |
Pebble Pounder Join Date: May 2013 Location: Torrance
Buy the spring kit. You need it for tuning the shocks. I run super soft in the rear and soft in the front with 35wt oil and I am liking how it feels.
10-18-2013, 11:34 AM | #490 |
Rock Stacker Join Date: Sep 2013 Location: Prescott
When you change out the lockers to ARB lockers, did you change out the gears or are you still running the stock one? If not, are you gonna go with the ones you have listed on the bulletproof thread?
10-18-2013, 11:55 AM | #491 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Still running the stock versions. I probably won't change them out for awhile. I have had pretty good luck with stock gears. I only change them out when they finally wear out which can take quite awhile.
10-18-2013, 12:17 PM | #492 |
10-19-2013, 06:20 PM | #493 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
When you do change them out what will you do. Over the front under the back ?
10-20-2013, 11:25 AM | #494 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Absolutely not. Not in a Wraith built for any speed. Too much stress on the axles accelerates bearing failure. I will either go back with stock ratio or under in both axles to add a little more reduction. Although the stock straight cut gears may be the best fit for not adding more stress on the bearings but I haven't really thought it through.
10-20-2013, 11:48 AM | #495 | |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Quote:
What is the stock gearing in those RTR axles? Thank You Harley for your time on these writeups and your videos. I've watched just about every one of them sitting here drinking beers. Nevermind, I just went and look in the manual I bought from RPP. It 38/13. Last edited by blackcruzer; 10-20-2013 at 11:52 AM. | |
10-21-2013, 10:03 PM | #496 |
Newbie Join Date: May 2013 Location: Craig, Colorado
On the Mamba what do you do with the on/off switch? Do you waterproof it or just eliminate it? Just kinda curious.
10-21-2013, 10:04 PM | #497 |
10-22-2013, 01:33 PM | #498 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Any comment on the HH trailmaster sport? Not even worth the $12 they're asking for it? Or is the $35 crawlmaster sport the way to go? Awesome videos, makes things much easier to understand |
10-22-2013, 01:35 PM | #499 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build If you are just looking for a super cheap sealed can motor than that's fine but I would really suggest spending the extra and getting a motor with some solid advantages over a sealed can motor.
10-24-2013, 09:13 PM | #500 |
Rock Crawler Join Date: May 2012 Location: Upland
No video today?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/450136-harleys-%2450-poison-spyder-wraith-budget-build.html | ||||
just bought wraith rtr, now what upgrades? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 08-05-2013 12:19 PM |
Harley's $50 Poison Spyder Wraith Budget Build - Similar Threads | ||||
Nikka's Poison Spyder Wraith Build | Nikka | Axial Wraith | 69 | 07-02-2016 01:55 PM |
Jeep Poison spyder wraith | allanon1965 | Axial Wraith | 33 | 08-14-2013 11:19 PM |
Poison Spyder Wreckluse Build | Guam_RC | 1.9 Scale Rigs | 39 | 02-26-2013 08:35 AM |
Billet's poison spyder wraith | Billet | Axial Wraith | 6 | 10-06-2011 10:35 PM |
