06-27-2013, 11:55 AM | #61 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Handling is fine for what it is. It didn't handle poorly before with the speed of the stock motor. It needs new shocks and I am debating on where in my schedule I am going to account for that. My biggest concern is trying to get enough money in the "bank" to be able to buy a good servo without having to skip a week of upgrades. This build has been a lot of fun for me so far. It's cool to get back to running a truck stock and upgrading slowly. Bringing a lot of the old memories and excitement back. |
06-27-2013, 12:14 PM | #62 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
cheap knock off servo but reviews seams like its pretty good. I should be having one delivered tomorrow and I'll let you know my first impressions when I get it. should be way better then stock and well under your weekly budget. Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear |
06-27-2013, 12:17 PM | #63 | |
Pebble Pounder Join Date: Jun 2013 Location: Greenbrier
| Re: Harley's $50 Poison Spyder Wraith Budget Build Quote:
06-27-2013, 12:27 PM | #64 | ||
Likely a Futaba S9157 which retails around $120-130. 425 oz/in of torque, 0.14 sec transit time, fully waterproof, etc. Servos are a tricky deal, specs can be deceiving and there are lots of options. I just say people should buy the best they can afford when it comes to a servo. Bargin hunting usually leaves you with a bargin servo. If you spend more, you usually get more. | ||
06-27-2013, 12:40 PM | #65 |
Rock Crawler Join Date: May 2012 Location: Upland
417 ounce/in for $17.50? I don't think so If you buy big body clips you can cut your own hex pins and make them long enough to fill the slot. There is less force from the pin to the hex due to larger radius of the pin. tau=rxF Last edited by z50king; 06-27-2013 at 12:42 PM. |
06-27-2013, 01:18 PM | #66 | |
I run the truck pretty hard, trying to break something in order to pick the next upgrade. I wasn't expecting the hubs to be the issue, I was guessing an idler gear before that really. | |
06-27-2013, 02:24 PM | #67 | |
06-27-2013, 02:39 PM | #68 | |
The CMS kit is for appearance reasons with getting the servo out of view. If you don't care about scale looks than you don't need it. | |
06-28-2013, 02:23 AM | #69 |
Pebble Pounder Join Date: Dec 2009 Location: ca
The solar servos dont last at all. I thought I would give them a try, and they only lasted a few packs before the lash on the gears was too much to stand.
06-28-2013, 06:38 AM | #70 |
Harley I think its time for you to try the hxt 10kg from hobby king and run it on 7.5volts This would really lightn the load on the budget. Maybe just as a shits and grins kinda thing HXT 10kg Servo (metal gear) 55g / 10kg / .16sec (USA Warehouse) |
06-28-2013, 07:32 AM | #71 | |
06-28-2013, 08:54 AM | #72 | |
06-28-2013, 09:30 AM | #73 |
Servo's will be a huge item of debate, this is for sure! Lots of people use cheap servos. Over my many years in this hobby I have found the true value in spending the money once in the correct places, servos at the top of that list. |
06-28-2013, 09:34 AM | #74 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: Harley's $50 Poison Spyder Wraith Budget Build i agree with that statement but also believe you can find a good long lasting servo for less then 100$ |
06-28-2013, 10:06 AM | #75 |
06-28-2013, 10:32 AM | #76 |
Pebble Pounder Join Date: May 2013 Location: Workshop
Are you planning on running this at night...? |
06-28-2013, 11:49 AM | #77 |
I'm now running a savox 1268 on 6 volts and it crawls pretty dang well. Bought it because it also work well on planes and helix which I also do. I would love the 1283. I've ran that hxt 10kg and never had a failure however I did brake a servo case while cartwheeling the wraith down the asphalt. These servos also work well as servo winches |
06-28-2013, 12:51 PM | #78 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build |
06-29-2013, 09:09 PM | #79 |
I have two questions Harley. Do you have a picture of where you mounted the BEC at? Also why do you need a set of 12mm Hexes when you install a set of VP 475 SLW hubs? Could you not use the stock set?
06-29-2013, 09:51 PM | #80 | |
The PSC Wraith does now come with hexes. It uses a pin drive in plastic hubs. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/450136-harleys-%2450-poison-spyder-wraith-budget-build.html | ||||
just bought wraith rtr, now what upgrades? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 08-05-2013 12:19 PM |
Harley's $50 Poison Spyder Wraith Budget Build - Similar Threads | ||||
Nikka's Poison Spyder Wraith Build | Nikka | Axial Wraith | 69 | 07-02-2016 01:55 PM |
Jeep Poison spyder wraith | allanon1965 | Axial Wraith | 33 | 08-14-2013 11:19 PM |
Poison Spyder Wreckluse Build | Guam_RC | 1.9 Scale Rigs | 39 | 02-26-2013 08:35 AM |
Billet's poison spyder wraith | Billet | Axial Wraith | 6 | 10-06-2011 10:35 PM |
