12-12-2013, 12:39 PM | #101 |
Pebble Pounder Join Date: Jul 2013 Location: matwin territory
Hmmmm, berry interesting do you have to go three link if you do go with the chassis mounted servo ?
12-13-2013, 04:40 PM | #102 | |
Moderator Join Date: Jan 2004 Location: chicago
| Re: scaleready wraith Quote:
with the 3link the panhard bar and the steering link (if setup right) will follow close to the same arc through suspension travel and elminate a good deal of bumpsteer. that said, i have a dingo that still uses the 4link with a chassis mounted servo and it works pretty decent. the only reason its not the 3 link with phb is ive been too lazy to install it. | |
12-15-2013, 05:24 PM | #103 | |
Thanks for the info! | |
12-16-2013, 11:51 AM | #104 |
| Re: scaleready wraith |
12-16-2013, 03:51 PM | #105 |
The search engine on RCC hates me for some unknown reason :( haha
01-14-2014, 06:38 PM | #106 |
03-18-2014, 10:22 PM | #107 |
little update. i swapped out the 3racing winch with a twin motor integy setup and a custom smaller dia. stainless spool from gripfab. it pulls pretty good on 3s with a heyok relay controller and a doubler pulley. it'll climb the winchline no problem. |
03-19-2014, 12:31 PM | #108 |
Quarry Creeper Join Date: Jul 2010 Location: My garage...
That winch looks sick Jason!
03-19-2014, 01:51 PM | #109 |
thanks dude! honestly the original 3racing winch did a pretty good job on 3s with a pulley. the stock winch spool proved to be the weak link, as i busted the threads in the grub screw that holds the spool to the motor shaft. |
09-13-2016, 09:36 PM | #110 |
RCC Addict Join Date: Mar 2010 Location: Yelm
bump for a sick rig!!!!!!! Can't wait to see the new decals on it!! |
10-10-2016, 07:45 PM | #111 |
Newbie Join Date: Oct 2016 Location: Rock Hill, South Carolina
What kind of power supply are you using? Sent from my iPhone using Tapatalk |
scaleready wraith - Similar Threads | ||||
Letsgojeep's Full steel wraith, by ScaleReady | ScaleReady | Axial Wraith | 46 | 06-29-2013 04:55 PM |
New ScaleReady *IFS Wraith chassis* feeler | ScaleReady | Axial Wraith | 2 | 03-18-2013 12:54 PM |
New ScaleReady *IFS Wraith chassis* feeler | ScaleReady | Axial Wraith | 45 | 01-29-2013 09:25 PM |
New ScaleReady *IFS Wraith chassis* feeler | ScaleReady | General Crawlers | 2 | 11-13-2012 07:14 PM |
