07-23-2013, 03:13 PM | #21 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Mad Skinz Wrexo Wrangler Build
You plan to run the mip front shafts? Breaking that one piece spool shaft had to have been a fluke. I have beat mine to death with big power without a failure. Looks good |
07-24-2013, 08:25 AM | #22 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
Thanx Guys, This chassis just has the GPM Cvds for the rear of an EXO. The MIPS are so big you cant run the Prolines SCT shocks in the stock location. The PL will have to run in front or outside the A-Arm. Both shock and MIP's are huge. Plus, I save about 7 ozs of weight not having MIPS. ....As the GPMs are being tested, Ive been hard on them with some full throttle launches and I bought a few more sets, JIC. |
07-24-2013, 09:45 AM | #23 |
| Re: Mad Skinz Wrexo Wrangler Build Check out my build thread. The shocks will fit in the stock location if you run the male bone on the diff side.
07-24-2013, 01:19 PM | #24 | |
| Re: Mad Skinz Wrexo Wrangler Build Quote:
Then Jay welded me up the stinger with a wider shock mount so they would have a lil more tension vs inboard spring. | |
07-26-2013, 12:54 AM | #25 |
............With the Electronics in the passenger seat, It sure cleaned up the rear bed. Those are also CFM rear bed sides. Last edited by scottanthony; 07-26-2013 at 12:55 AM. Reason: .. |
08-24-2013, 01:34 PM | #26 |
Well, before I had completed the side panels and worked anymore on this, I had been waiting on these to arrive and mount them on the Wrexo Wrangler, Axial 12021 BFGoodrich, Krawler T/A, KX White Dot R32 Tires Axial BFGOODRICH KRAWLER™ T/Aź KX TIRES (2) Thanx RPP!! Last edited by scottanthony; 08-24-2013 at 02:45 PM. Reason: .. |
08-24-2013, 01:59 PM | #27 |
Oh, yeah.... Its more proportional and scale.. |
08-24-2013, 02:16 PM | #28 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
Any vids of this thing in action?
08-24-2013, 02:44 PM | #29 |
Ill have some runtime on it today.. but not yet..
08-24-2013, 10:49 PM | #30 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
looking good!
08-25-2013, 04:44 AM | #31 |
Finally got around to adding the Mad Skinz Open Hood Kit. Its the best way I could think of doing it by trimming from the fender. |
08-28-2013, 02:04 PM | #32 |
The Proline Power Stroke Big Bores have really brought life to the truck as a Go-fast. |
09-10-2013, 11:14 AM | #33 |
Heres some pics on the trail.... |
09-10-2013, 11:17 AM | #34 |
It crawls too for being sooo low. |
09-10-2013, 11:20 AM | #35 |
Super stable on the chunky Rock. |
09-10-2013, 11:22 AM | #36 |
Lean..? What Lean..? Couldn't get it to rollover. Last edited by scottanthony; 09-10-2013 at 11:37 AM. Reason: ... |
09-10-2013, 11:25 AM | #37 |
Rock Crawler Join Date: Jun 2012 Location: jville
how are the cvds holding up and what setup are you running?
09-10-2013, 11:38 AM | #38 |
I used one of Ricks, Lockers (Grip Fab V2) cause Ive never broken one yet and luv the 4 set screws which even out both the drive cups so they don't wobble. Heres a pic. |
09-10-2013, 11:52 AM | #39 |
Those are Cvds off an EXO. They were bout $20 and have held up to 3s, 5000kv 4pole motor geared pretty high. You need to run Rear 96mm length shafts and add a piece of cut nitro fuel line. |
09-10-2013, 11:58 AM | #40 |
...........But, I couldn't wait to order a set of these Motorworx Murdered Out 2.2's from the Scale Addict..... » 2.2 8 Spoke SLW Murdered Out - The Scale Addict They are going to look the best for my choice of upcoming color scheme....! |
Mad Skinz Wrexo Wrangler Build - Similar Threads | ||||
Mad Skinz Axial Rubicon JK Soft Top | scottanthony | Vendors Miscellaneous | 47 | 05-28-2014 07:00 PM |
Mad Skinz Wrexo Early Bronco | scottanthony | Axial Wraith | 20 | 06-22-2013 07:47 AM |
