09-26-2013, 11:59 PM | #61 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
| Re: Mad Skinz Wrexo Wrangler Build
Heres the comparison of the two.. EXO chassis is wider.. BMRC KIT is skinnier and cleaned up. |
10-03-2013, 09:47 PM | #62 |
With the upper plate installed, The servo is going to ride on my 5000mah Lipos.. Not sure if that's a good thing.. Also, the screw for the servo horn likes to hit the upper plate. I had to grind down the plate in the spot it was hitting. Last edited by scottanthony; 10-03-2013 at 09:51 PM. Reason: .. |
10-03-2013, 09:49 PM | #63 |
I do like the plate is lower than the forward batt tray used to rest on. Drops it about 3/8 of and inch. |
10-09-2013, 11:52 PM | #64 |
Not sure if it was my Proline shocks or the angle of the bend but I had to straighten it a lil to just mount the bolts. |
10-09-2013, 11:55 PM | #65 |
Front here, it looks better............ I can imagine how much abuse im gonna run this set up thru now. |
11-29-2013, 09:24 PM | #66 |
Side shot of the BMRC kit.... |
11-29-2013, 09:26 PM | #67 |
.........Just when it was all going together, ..... I ran into this............. Something was waaaayy off. Quick note to builders, leave the other parts loose until the lower pan is attached. |
11-29-2013, 09:28 PM | #68 |
I did get everything to mount up after I loosed the other screws.... |
01-13-2014, 01:27 PM | #69 |
I went ahead and added the aluminum diff case. It clamps down the bearing sides to eliminate diff slip |
01-13-2014, 01:45 PM | #70 |
Not sure how to mount this plate but they don't squeeze above the diff housing. |
01-13-2014, 01:53 PM | #71 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Kinda hard to see but it goes up against the top plate. The slots go where you would have mounted the rack before on the top plate. Then you can move the steering forward. |
01-15-2014, 03:45 PM | #72 |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
How's the steering throw on the BM kit. I'm reading a bunch of problems with the angles.
01-15-2014, 04:44 PM | #73 |
Pebble Pounder Join Date: Oct 2013 Location: Valencia, Crawlifornia
| Re: Mad Skinz Wrexo Wrangler Build |
01-27-2014, 05:41 PM | #74 |
Heres a quick Vid of the BMRC Kit in action [IMG][/IMG] |
01-28-2014, 08:45 AM | #75 |
Im still working on the steering angles for the BMRC Kit. I may have a solution coming up.. Pics will follow.
01-28-2014, 10:04 AM | #76 |
Looks like there's decent steering. Can you take a vid of doing u-turns like a tight infield course?
01-28-2014, 12:29 PM | #77 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
01-28-2014, 05:51 PM | #78 |
Where did you pick up that aluminum front diff case? Good looking build |
01-29-2014, 06:44 PM | #79 |
01-29-2014, 06:57 PM | #80 | |
| Re: Mad Skinz Wrexo Wrangler Build Quote:
(I found it.............) http://asiatees.com/display?Axial-EX...id=56397&pid=1 Last edited by scottanthony; 01-29-2014 at 07:03 PM. Reason: .. | |
Mad Skinz Wrexo Wrangler Build - Similar Threads | ||||
Mad Skinz Axial Rubicon JK Soft Top | scottanthony | Vendors Miscellaneous | 47 | 05-28-2014 07:00 PM |
Mad Skinz Wrexo Early Bronco | scottanthony | Axial Wraith | 20 | 06-22-2013 07:47 AM |
