"Ball Pein Hammers" tear down after a G6- what to really expect First of all there is nothing better than being a competitive natured dude in the RC Scaler scene...I LOVE IT! But whether you are or not there are certain things that take place that make you be a big boy and wrench a bit just to maintain. Trust me I used to be that guy, NON Maintenance, just giver hell and forget about what the outcome is. In this thread I'm going to give you a step by step of my tear down after a 200 gates in one day, with mud, water, and rocks. Oh and freekin "Scale Horspower", which is a big factor. Keep in mind in this thread Ill talk about my bearing around the pinion shaft (damn critical with horsepower in wraith axles) and all the other bearing a crap that you don't see unless tore down!! Come along now! 1st thing first, lets set her up and pull her shoes off and get some stuff broke lose. I try to do this fast after a tough run because rust sets in and destroys, plus the mud just get harder and harder to get off. http://img.tapatalk.com/d/13/07/23/uqyjety5.jpg As you see here the grass gets nested up around the hubs inside the wheels. Bad stuff as it holds rocks and other foreign objects that cause unnecessary ware. http://img.tapatalk.com/d/13/07/23/y9ary9av.jpg After you get your shoes off you can pull the axles and see whats in store for you. It sucks but has to be done. http://img.tapatalk.com/d/13/07/23/e5a4uru8.jpg Once the axles are pulled out, get a pic and start cleaning the heads of the screws out so you can get your driver in there without the strip effect. http://img.tapatalk.com/d/13/07/23/sugehe2u.jpg This is a pic of the diff cover pulled. Now just imagine what could of happened if you didn't start this crappy clean up!!! http://img.tapatalk.com/d/13/07/23/du9utyqa.jpg Next we will get into the axle deeper. Might even give a lil love to a brand new Hitec 7955 that made the voyage. ALL THIS IS A MUST Thanks for looking |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect I'll be watching. It's one of my favorite rigs |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Awesome, great thread. "thumbsup" |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Mighty1 now try and do this 10 times a year just for the g6s plus the other 5 to 10 scale runs pain in the a$$ :lmao::lmao::lmao:thats why we love parker "thumbsup" |
Yah I can imagine and yes he is loved! Lol. http://img.tapatalk.com/d/13/07/23/5u9a8ydy.jpg |
6 Attachment(s) As I get further in the axles I start finding really bad stuff happenin. Now these axles did have run time on them so can exactly tell you how long but the bearings were fine and everything had grease. As I tear into them I find out quick a whole new bearing kit from Fast Eddies is in order. Attachment 247532 As I said before the lockers and gears looked new until the G6 Attachment 247533 The knuckle bearing really took a beating. Maybe had something to do with the lose o the passenger axle Attachment 247534 Attachment 247535 This is a pic of the axle that made it. Notice the Bent to hell pin Attachment 247536 Next post ill discuss the servo. I'll show you the inside of a new Hitec after a 200 plus gate event. Attachment 247537 |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect That was a good g6 we had..the mud took its toll on alot of trucks. Novaks and castles were going up in smoke, my t3kin kept right on trucking. Waterproofing and spraying the truck down with wd40 the night before will help with the rust and cleanup. My biggest problem and critical area is going to be replacing all the drive pins on everything. I kept snapping them during the recon on the slipper,wheel hexes,and mip's. "thumbsup" |
My MMP and Pro 4 held up flawlessly. Harley and I finished first stage together. He helped me limp through last 20 gates do to front CVD pin chop lol. Oh and my MMP had no fan. |
Subscribed... Very cool From my Galaxy S4 |
1 Attachment(s) HAfter I got the axles tore apart I put all the hardware on some bucket of cleaner. This will remove all grease, rust etc. you can see the lockers floating around. http://img.tapatalk.com/d/13/07/24/ytevezy3.jpg After I get em all cleaned the bearings will be replaced by Fast Eddie bearings. The old ones that survived will be put in my pit bag. http://img.tapatalk.com/d/13/07/24/e6a2upa5.jpg The reason new bearing are important is the fact the pinion shaft bearings just don't hold up long with a lot of "Big" horsepower. Remedy new bearings often if your racing. If the bearing goes most of the time your diff gears an pinion will be had. Another remedy is the brass bushings from Vanquish. Harley is running those now and testing. Check out his "Hit and Run" build for updates. Attachment 247559 |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Wish there was more interest in scale comps over her in Idaho, sounds like you guys had a blast. That inner knuckle bearing to me seems to be a weak point. Doesn't matter if the bearing is brand new or seen some run time. It will emplode on itself. I still haven't seen the reasoning behind buying fast eddy packaged bearings. Hopefully your phones on the charge. |
Ditto |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Good idea for a thread. I do this to 3 wraiths after each event. And we just added a 4th to the fleet. G6 family 8) |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Ohhh I use Boca bearing oil in all my bearings. Thought about some abec 5 bearings but I really don't think a higher dollar bearing is going to lastmuch if any llonger in bashing crashing environment. All it takes us one hard impact and the bearing is weekend or spitting itself apart. |
Well I hope this thread get people to realize the damage faster than it took me. Lol I've been messing with RC for 5 or so years now and seen a lot of preventable damage happen. |
5 Attachment(s) Well I decided to crack open the ok Hitec today. Grizzly thought me a long time ago to just buy em and giver hell. This is why. Cracked her open and whalla no water! Attachment 247717 Attachment 247718 I also like the seals and o ring around the output Attachment 247719 Bit since I cracked her open I did decide to freshen up the seals and board with Dielectric grease. Put her back together and just put a touch of liquid tape around seams for good measure. Attachment 247720 Attachment 247721 Check!!! servo on great shape!! |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect Looks like savox internals along with the snazzy seals. Who makes hitech servos???? I'm just kidding |
6 Attachment(s) Today I tore down my CLAW winch. Excited to see it was still perfect but showed some signs of water. So I disassembled and addedse grease and its back to awesome! Attachment 247803Attachment 247804 Attachment 247807 Attachment 247805Attachment 247806 Attachment 247802 |
Re: "Ball Pein Hammers" tear down after a G6- what to really expect it's gonna sparkle! |
Johnny my Fast Eddie bearings will be put in tomorrow and my Super Shafty Tranny will arrive. She will live again tomorrow!!! |
