08-11-2013, 11:33 AM | #41 | |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Newbie Wraith build Quote:
It wouldn't hurt to hear an ETA, you may be able to pre-order of something. VP's OMF BL are a very sharp looking wheel and they should definitely handle what you will put the Wraith through. The bead locking system couldn't be easier; it's only 5 screws to mount up a tire. | |
08-11-2013, 01:03 PM | #42 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
Yea supershafty bomb trans is worth every penny!
08-11-2013, 07:07 PM | #43 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
You can build a wraith tranny for cheaper. No need for the beefy top shaft, or the gen3 slipper. A traxxas jato 56tooth spur will fit under your cover. Rrp idiler, and bottom gear with supershafty 6mm outputs, with 6mm mip yolks. All of that shoved in a hotracing wraith tranny case.
08-11-2013, 07:37 PM | #44 | |
Lets break it down: Complete Bomb Proof WRAITH Trans - Super Shafty $200.00 plus shipping If you built it yourself: Hot Racing Hardened Steel gear set: $29.00 Hot Racing Wraith case: $38.00 SuperShafty 6mm outputs: $68.00 MIP Wraith driveshafts: $62.00 MIP 6mm joints: $7.00 each- $28.00 Then roughly $15-20 for shipping Just right there alone, you're running a $240 transmission. That isn't including the Beefy Top Shaft, RRP Spur gear or SuperShafty motor plate. Last edited by Lentsnh2012; 08-11-2013 at 07:42 PM. | |
08-11-2013, 07:38 PM | #45 | |
08-11-2013, 08:24 PM | #46 |
Pebble Pounder Join Date: Feb 2013 Location: El Dorado Hills
Nice build you got going! Can't wait to see the finished rig. Seeing as everyone else is giving feedback on what trans to get, I'll throw in my $0.02 AX2 w/HD output shaft. -$145 + $35 for shift servo. Wraith Pro4 2 speed |
08-11-2013, 09:53 PM | #47 |
Pebble Pounder Join Date: Mar 2012 Location: Everett
Just a question/observation of sorts. People get the AX2 trans which once you get a servo is around 180 but couldn't you instead invest that money in a good remote? (4pls or other programmable remote) With that remote couldn't you program a switch so that it drops the motors power by fifty percent(or what ever power output would work best) then when you want to go blasting off click it back the other way? I know futaba remotes have the ability because of dual ESC mixing but you could in theory use it for an electronic first and second gear and use a bomb proof tranny. Not to mention you wouldn't have to worry about servos failing.
08-11-2013, 10:01 PM | #48 | |
08-11-2013, 10:58 PM | #49 | |
Pebble Pounder Join Date: Jun 2013 Location: Greenbrier
08-11-2013, 11:04 PM | #50 |
| Re: Newbie Wraith build Many people are using a 645mg, I decided to run a 625mg micro mounted underneath. It has held up with zero issues. Yes it can be shifted on the fly, in the video I posted I'm shifting it. I don't want to jack this thread though, if you have any more questions please PM me |
08-11-2013, 11:16 PM | #51 | |
Rock Stacker Join Date: Aug 2013 Location: Beaumont AB Canada
Interesting, I may have to try that in one of mine... | |
08-11-2013, 11:31 PM | #52 |
With a good brushless motor like the pro4 or roc412 there is no need for a 2speed trans. The motor is planty fast and had more torque than you'll need.
08-12-2013, 12:27 AM | #53 | |
((Hey sorry Cale kind of off topic don't want to hijack your thread.)) As for what you run in your wraith my only suggestion is WATERPROOF EVERYTHING! Its much more fun running in mud and water unless you have sand. kicking up tons of sand is also just a good time. Last edited by GuyOverThere; 08-12-2013 at 12:38 AM. | |
08-12-2013, 06:37 AM | #54 |
My personal thoughts on using the 2sp was from a heat standpoint. I like speed, and in order to achieve that speed I was after, a bigger pinion would be needed. In my first truck, I burned up a few motors and ESC's looking for that speed. With the 2sp, I am able to run a 12t pinion and still have awesome top end in 2nd gear because it's a higher ratio than the stock transmission. I can honestly say, this is MY first pro4 motor, and I didn't know a whole lot about them prior to buying it last week. My LHS told me it was a great motor, but they have sold me a lot of stuff I don't need so I wasn't 100% sold on it..... Till now! I am also very partial to my 2sp and would recommend it to anyone |
08-12-2013, 01:24 PM | #55 |
Now that i got my rrp gear back from warrenty, it hasn't had one problem under big power.
08-12-2013, 01:54 PM | #56 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
If by 'hotwire' you mean 'Hot Racing', stay away from HR crap too. The press-fit retainers will come out and throw a ton a slop in your rig. HR links - worthless!!! Get VP or make your own. |
08-12-2013, 02:16 PM | #57 | |
08-12-2013, 05:46 PM | #58 | |
Hardware showed up today, assembly can start...Thank You Nicole Last edited by Cale262; 08-12-2013 at 05:51 PM. | |
08-12-2013, 06:13 PM | #59 |
Boom! There it is! My opinion about the 2 speed transmission: - How much do you think you will really use it? When I had the TF2 up and running, I barely used high gear. - Is it really worth it in the long run? There is more parts that could break and more to maintain I think just having a single speed transmission with dig will do just nicely for you. I would stick with the single speed transmission first and then move on to a 2 speed if you have the need for it. Just my $.04. |
08-13-2013, 10:40 AM | #60 |
I will be sticking to the single speed transmission for this build... My goal, being fairly new and having already experienced the RTR failures, is to keep this build simple and reliably stout. Going to assemble the chassis today.
Newbie Wraith build - Similar Threads | ||||
newbie wraith vid | evan03 | Newbie General | 0 | 12-24-2012 10:09 PM |
Wraith newbie question. | Jigs | Axial Wraith | 4 | 12-14-2012 11:08 AM |
newbie Wraith questions | chrisring | Newbie General | 9 | 07-05-2012 11:19 AM |
Newbie with a Wraith on the way, few?'s | mrmagoo | Newbie General | 4 | 11-26-2011 07:24 AM |
Wraith Question from a Newbie | Swiss | Electronics | 2 | 06-19-2011 09:36 AM |
