07-03-2014, 02:37 PM | #1 |
Rock Stacker Join Date: Jun 2014 Location: Europe
| My Wraith...in the future fast !
Hello, At first > sorry my very bad english ( google translate bad ). This is my first axial Wraith! I am trying to build wraith fast, but this build take a long time maybe one - two year ? My Wraith update 4.10.2014 parts: Gearbox parts: Hot Racing Aluminum Center Transmission Case for the Axial Wraith Hot Racing Super size heat sink Motor Plate you need > axial transmission spacer 5x6.9x4.8mm ( AX30499 ) This is a aluminum part ! gear: Axial Wraith Hardened Steel Idler Gear ( 1551 ). Axial Wraith One Piece Hardened Steel Outdrive/Diff Locker Gear ( 1555 ). Axial Wraith 80t Gen3 Slipper unit 48p. ( 1545 ). > put the new all bearings << buy I recommend !!! Axial Heavy Duty Gear Set x2 ( AX30395 ). Steering, Chassis and rear Vanquish part: Wraith Titanium Tie Rod Ackermann ( VPS03111 ). Wraith Arms Ackermann ( VPS03210 ) "I do not now get the blue" Wraith Titanium 3/16 Drag Link ( VPS03122 ). XR-10 Wraith C Hubs ( VPS02014 ). Wraith Steering Knuckles ( VPS03204 ). Rear > Wraith Rear Lockouts ( VPS03223 ). Vanquish Wraith 3/16 8pc link set ( VPS03137 ) Vanquish Wraith axle link mount BU ( VPS04723 ) Vanquish Bearing Caps BU ( VPS04743 ) Integy Billet Machined tube frame skid > Plate for Axila Wraith ( C24155BLACK ) Hot Racing Unibody Super heavy duty differential lock ( SCP125R ) Motor: Holmes Hobbies crawlmaster pro 540 11T. Pinion: Robinson racing 16T. Servo: Savöx SC-1256TG. BEC: CastleCreations BEC ( modify Castle Link > 6.0 V ). Cardan: MIP11116 cardan. Tires: rc4wd Mud Slingers 2.2 ( part number Z-T0097 ) Wheels: ( changed ) axial 2.2 8 Hole Beadlock and Jeep wraith you need example > axial 12mm aluminun Hub Hex wraith. ------------------------------------------------------------------------------------------------------ Standard (old) parts: ESC: Standard Axial AE-2 ( modify Castlecreations Link ) act 3S Lipo. Battery: (old) 3S Lipo 2200mAh ( maybe future 3000-4000mAh ). Now yet other wraith parts standard, but "all" wraith parts change in the future !! ( CastleCreations ESC, Tekin Brushless motor, Vanquish, Super shafty, Robinson Racing, Axial heavy duty...) My wraith be badly unfinished because axial ESC the back is a quick Policy ! The first test drive and here photos ( I do not know to show images or not ). Last edited by axsand; 10-04-2014 at 10:56 AM. Reason: update parts list 4.10.2014 |
07-04-2014, 03:54 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Litchfield park
| Re: My Wraith...in the future fast !
Looks really nice!
07-04-2014, 04:28 PM | #3 |
| Re: My Wraith...in the future fast ! |
07-04-2014, 05:21 PM | #4 |
Yesterday i start testing driving... then immediately at the beginning of motor to move aside pinion the does not take spur gear ( sorry my very bad english ). I tightened the screws very tight, but does not help. Maybe motor too powerful standard Spur and gearbox ? Now i think order all metal gearbox parts or supershafty wrait gearbox ( end ) or buy wraith aluminun gase and robinson racing gears, but I do not know which would be the best option fast wraith ?? ( easy adjust and get easy item / good action ). Spur 32P 56T or 48P 80T ? ( i have pinion 48P, but get 32P, if need ). |
07-04-2014, 08:57 PM | #5 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
Did you tighten the pinion set screw and adjust the slipper clutch? If they are both good, you probably stripped the plastic bottom gear in the transmission. I run the Axial hardened steel gear set with the Axial outdrives and the new Robinson Racing slipper with no problems. I also use the Vanquish motor mount, it feels really solid.
07-05-2014, 05:44 PM | #6 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Looks nice but check out Harley's thread on here about a bullet proof wraith, it will help a ton for the newbs. I reccommed a Savox sa-1231sg, there a lot more powerful than the 1256's.
07-06-2014, 05:29 AM | #7 | |
| Re: My Wraith...in the future fast ! Quote:
Adjust the slipper clutch...aaarrkk i did not remember, but should not be due to. I driver warith and Motor move ! Now again all screw OK and i testing today and i wacth what happen ? Vanquish motor mount wraith? this ? > http://ep.yimg.com/ay/yhst-196145921...ar-guard-8.gif whether other brand aluminun center transmission case, when Hot racing ? i have home savöx sc-1256TG ( scx10 spare part and i put wraith...money little ) Last edited by axsand; 07-06-2014 at 05:33 AM. Reason: added savöx... | |
07-06-2014, 01:08 PM | #8 |
Now go broke wraith standard Spur gear ! and driving testing end again. Does not come here for nothing. Apparently too much power plastic gear. Now waith more money and when order all aluminun: aluminun center transmission case, transmission gear, Spur gear, i order someting gear and transmission case ? wraith standard gear and transmission be shit and wraith motor move always !! If you order wraith, so ORDER / BUY the first to 1.all metal gear ! 2.better motor plate ! ( transmission case ! ) Last edited by axsand; 07-07-2014 at 07:10 AM. Reason: remove / to edit the text |
07-17-2014, 06:34 AM | #9 |
Vanquish part coming home. I buy blue color, because because my wraith come future blue, white, black color. Now to get photos show, when you get the car intact take more pictures. Now my wraith broken gearbox and i wait Robinson racing and hot racing part come soon! i update new parts always first page. |
07-19-2014, 03:07 PM | #10 |
My c hub is upside down sorry false information. I do vanquish parts wraith last night and i be tired. All right. I know > Vanquish parts best why to buy. Last edited by axsand; 07-20-2014 at 04:16 AM. Reason: New information and remove false information |
07-19-2014, 03:27 PM | #11 |
Something good > Gearbox parts coming and i build "own special" gearbox. I hope this act and be good, but we``ll see ? Hot Racing aluminum gearbox constitution quide did not had try out different screws what to visit where, but else easy. BUT axial transmission spur gear cover i do not find screw > hot racing Super size heat sink Motor Plate. put the new bearings except large not be home << buy ready I recommend !!! again i update fist new parts info. Last edited by axsand; 07-19-2014 at 03:52 PM. Reason: added to the thing |
07-21-2014, 03:04 AM | #12 |
You need Transmission part this > AX30499 transmission spacer 5x6.9x4.8mm ( aluminum ) find scx10 parts OR you have got to put standard plastic part ! I recommend buy all new bearings...for ease of installation ! New car i recommend first buy all aluminum transmission parts and metal gear and MIP cardan. What i buy read the first post. |
07-21-2014, 03:11 AM | #13 |
I do own MIP cardan bolt ( act 2.0mm Hex Driver ), but if the use of Transmission Spur Gear Cover, so that bolt does not. But axle side act. Lower bolt > |
07-21-2014, 03:14 AM | #14 |
Photos "testing driving" new Transmission and gear parts. Maybe someday testing sand and coming photos ? |
07-21-2014, 03:22 AM | #15 |
Battery box and ESC, BEC back. I do not recommend this fastback, because "side" screw not would take closed ! ( little hard ). I later to fix the back of the traces. Last edited by axsand; 08-14-2014 at 02:51 PM. Reason: testing new photo... |
07-21-2014, 04:24 PM | #16 |
I like your folded up lexan roof piece that you used for you new battery tray!
07-22-2014, 03:00 PM | #17 | |
Now my hard to understand what you mean ? My english very bad and google translate bad. But you like and thank you. I will make my battery "box" candy box cover.My battery box will not be very good....a bit tricky to do, but act and sufficient me. | |
07-23-2014, 08:39 AM | #18 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
I like how you did your front hood. The white one is my O.P.A.T. Wraith with a Proline Jeep Wrangler Rubicon body on it. I have been debating on how to create an opening hood on it. I may copy your idea. |
07-23-2014, 08:43 AM | #19 |
If that is a 3S 2200 LiPo battery pack, you can put your ESC and BEC in the battery bos with the Battery Pack and move the weight up front. |
07-23-2014, 03:01 PM | #20 | ||
Get your copy my hood idea, if you want. I can tell you how I make the hood, but now I do not have time to tell or show . Tomorrow, Thursday evening, and had the time to tell and put photos < if you need "quide" / information. Quote:
I want to keep ESC and BEC back and future next year ESC be castlecreations maybe Mamba Max Pro. | ||
My Wraith...in the future fast ! - Similar Threads | ||||
Scaler exo or fast wraith | dieselmudder | General Scale Talk | 4 | 03-29-2013 10:51 PM |
