09-10-2013, 08:44 PM | #41 |
Rock Stacker Join Date: Mar 2009 Location: Dawsonville
| Re: New Wraith! |
09-13-2013, 06:41 PM | #42 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Figured I'd show off my new mods before I install it. Vanquish case, HR gears, supershafty outputs, MIP shafts, 6mm outputs. Also have added titanium links and a axial clamping servo arm. When I get it all buttoned up tomorrow I'll take some pics. |
09-14-2013, 02:28 PM | #43 |
Here ii is all put together. Question, do metal tranny gears make some noise ? When driving very slow there is a slight clicking noise. Can also be heard holding truck and spinning tires by hand. Didn't do it before. This is what I did before it started making this noise. VP tranny case, HR steel gears, supershafty 6mm chromemoly extended outputs, MIP driveshafts. After these mods it started making the noise. I took it apart and it all looks fine. Bearings only have 2 runs on them and all spin great. Defiantly coming from tranny area. I also just changed from the stock gearing to 15/87. Last edited by Tmaxxed; 09-14-2013 at 02:36 PM. |
09-17-2013, 08:29 AM | #44 |
Newbie Join Date: Jun 2013 Location: Springfield
| Re: New Wraith!
Like the hood mod.
09-17-2013, 08:50 AM | #45 |
09-17-2013, 12:06 PM | #46 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: New Wraith!
check the set screw on the pinion see if it is rubbing. That will cause the clicking also check the motor plate as if it isn't straight you will get a click from not having proper mesh to the spur. last make sure you are not missing any teeth on the spur. Try those first
09-17-2013, 12:19 PM | #47 | |
09-23-2013, 12:19 PM | #48 |
Just ordered up a castle MMP and a tekin pro4. Damn, this is getting expensive!
09-23-2013, 12:27 PM | #49 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: New Wraith!
Hopefully the 3300. Gear the diffs as low as possible 13/43 with HD gears only and try 15/56 at the trans. You'll love it on 3s. Hope your packs are high C rating and quality cells. J |
09-23-2013, 01:19 PM | #50 |
| Yep the 3300kv. I have the stock ratio HD gears and 14/56 at the trans. Hopefully that'll work. I got some good gens ace lipos.
09-23-2013, 01:21 PM | #51 |
| Re: New Wraith!
And a good time you will have. Keep an eye on your packs. They are the weakest link in your/my setup. J |
09-23-2013, 02:21 PM | #52 |
What happens to them? I only have 2s packs right now but I plan on getting some good 3s packs when I pay down my recent credit card purchases.
09-23-2013, 02:32 PM | #53 | |
| Re: New Wraith! Quote:
J | |
09-23-2013, 03:18 PM | #54 |
| Re: New Wraith!
That is really good advice as most think a lipo is a lipo.
09-23-2013, 07:06 PM | #55 |
I think my lipos are up to the task. What's a MA lipo? I Google searched and it and found nothing.
09-23-2013, 07:17 PM | #56 |
| Re: New Wraith! |
09-23-2013, 07:48 PM | #57 |
09-28-2013, 11:22 AM | #58 |
I finally got my castle MMP/tekin pro4 installed. It cogged very bad at first then I realized the sensor plug came out. Plugged that back in and now it works great. Crawls well and is a blast at high speed. I just have it running on 2s right now but I will grab some 3s lipos soon. Its pouring rain outside right now but I'm going to run it more as soon as it clears up.
09-28-2013, 03:08 PM | #59 |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
| Re: New Wraith!
Nice! Running video please!! |
11-12-2013, 09:22 PM | #60 |
I'm resurrecting my old thread here. I've done a lot to my wraith lately. I just put a bunch of BGR stuff on it and I'm waiting for my new Gcm axles and pitbull rock beast 2's to arrive. I bought some 3s lipos for it and wow, it rips with the pro4. Very fun to drive. I just cant belive the money i have put into this thing. This was supposed to be a budget friendly build, now im into the mid $2500's. Ouch!! Here is how it sits right now. Sorry for the poser shots. It's all I have right now. Sent from my SAMSUNG-SM-N900A using Tapatalk Last edited by Tmaxxed; 11-12-2013 at 09:25 PM. |
