Thread: VP Currie Rock-Jock rear swaybar issue.
Old 09-05-2013, 08:20 AM   #1
Default VP Currie Rock-Jock rear swaybar issue.
I tried to mount my Axial sway bar to my rear Rock-Jock and discovered that the drivers side lower mount would contact the axle pumpkin. I decided to breakout the Dremel and remove some material from the pumpkin.
Here are some before and after pictures.
LucasAutomotive is offline   Reply With Quote
Old 09-05-2013, 01:35 PM   #2
Default Re: VP Currie Rock-Jock rear swaybar issue.
Nice job. How are you liking the sway bar?
Calderwood is offline   Reply With Quote
Old 09-05-2013, 03:32 PM   #3
Thanks!
It works great for reducing torq twist and body roll. I am running the lightest bar and I would say 90% of my torq twist is gone. It does reduce articulation more then I like, so I run the rear sway bar only. I have thought about reinstalling the front sway bar with piano wire instead of the supplied bars to see if that helps.... just need to find time.
VP Currie Rock-Jock rear swaybar issue. - Similar Threads
VP Currie Rear Axle Assembly PrjktRedRubi Axial SCX-10 7 12-27-2012 06:20 PM
anyone use the dinky rear tray with the HR swaybar kit bagged86 Axial Wraith 5 03-06-2012 04:26 PM
