09-11-2013, 01:51 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
| Mad Skinz Terra-Wraith IFS Build
So, it seems as if the only Down time I have is at around Midnight due to work and family. Im not sure if I get restless or all the ideas have stacked up in my head to the point I feel the need to rip something apart. ...? .....And like most of us, I have boxes of Axial parts laying around. Then there was a lil EXO sitting on the shelf, itchin to get a new look so, heres what a late night of restlessness brought me. |
09-11-2013, 07:21 PM | #2 |
Quarry Creeper Join Date: Mar 2008 Location: Hot Springs
| Re: Mad Skinz Terra-Wraith IFS Build
Any details on how you did it? I might just have to do this.
09-11-2013, 09:05 PM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Nice! Is it ready for a shake down run yet?
09-12-2013, 10:56 AM | #4 |
Ive been ripping it up.. I stripped the hexes and muched a bead being a Hoonigan. Im still working on the foam compound but man its fast..
09-12-2013, 10:59 AM | #5 |
Basically just cut the Wraith cage lower braces off the sides which mount to the frame rails. |
09-12-2013, 11:07 AM | #6 |
Whats nice. (...and we can Thank Axial's Design team for) is that they line up with the factory EXO side mounts and are the exact size, width and length. All four corners will screw right to each other, so you will use existing holes. But, the cage will need to be drilled about 30mm inward/upward. |
09-12-2013, 11:24 AM | #7 |
| Re: Mad Skinz Terra-Wraith IFS Build |
09-12-2013, 06:53 PM | #8 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Was all you used from the wraith is the cage? Do you have a pic with the hood open? Thinking of trying this out. Just wondering what all the parts I need are.
09-12-2013, 08:15 PM | #9 |
I do have pics... I actually have a lot more and a few other goods that might interest you too.
09-12-2013, 08:17 PM | #10 |
Front view under the hood. There is no mounting place under here between the lower and the upper. |
09-12-2013, 08:19 PM | #11 |
The rear is mounted to a cut center section on the Wraith. The stock EXO skid was never removed. With some trimming, they will go together. |
09-12-2013, 08:23 PM | #12 |
Thanks. for the pics. Planning a winter project.
09-13-2013, 09:41 AM | #13 |
09-13-2013, 09:45 AM | #14 |
The rear of the cage has to be strengthened. Youll need a link between the two cage sides to take up flex. I also wanted mine stiff as possible. So, a few spacers and I moved the shocks out. But the lower shock mount has to be moved if you want the rear to squat. |
09-13-2013, 02:54 PM | #15 |
After seeing this thread, I decided to do this. I cut the "tube" on the Wraith to slide into the EXO holes. Now the rear is a tad high, even with the shock mount flipped, but a little massaging to the front and all will be good. Killer idea man.
09-13-2013, 07:32 PM | #16 | |
| Re: Mad Skinz Terra-Wraith IFS Build Quote:
Just eliminate the rear shock mount all together. It will fit in the shock hole inside or out. Last edited by scottanthony; 09-13-2013 at 07:33 PM. Reason: .. | |
09-13-2013, 07:39 PM | #17 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
Schuweetnesss! I like what you did!
09-13-2013, 07:53 PM | #18 |
Heres the rear. I used an angled link mount which keeps it from binding. Last edited by scottanthony; 09-14-2013 at 09:57 AM. |
09-15-2013, 11:01 AM | #19 |
Changed the panels and wheels around w/some hydrographed Carbon Fiber. Thanx goes out to Dave at Hoggskinz, who can do just about anything. Hard Bra Inventor,Camo dipping specialist, Water Transfer Printing ,Camo Dipping , Hydrographic Printing Process |
09-15-2013, 10:07 PM | #20 |
That looks good. I like it.
Mad Skinz Terra-Wraith IFS Build - Similar Threads | ||||
Mad Skinz Wrexo Wrangler Build | scottanthony | Axial Wraith | 86 | 03-09-2014 10:49 PM |
Szczerba's IFS Wraith Build #2 | Szczerba | Axial Wraith | 22 | 01-16-2014 11:59 AM |
Mad Skinz WraithO Build | scottanthony | Axial Wraith | 24 | 11-25-2013 10:00 AM |
Real-time IFS Wraith build. | JasonInAugusta | Axial Wraith | 66 | 10-12-2012 01:59 AM |
