04-07-2014, 07:15 PM | #81 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
| Re: Harley's Wrexo
good to know. i think i know the answer but i must ask did you move the drag link on the bell crank to the top of the bell crank? I'm thinking you did. |
04-07-2014, 07:20 PM | #82 |
| Re: Harley's Wrexo I tried moving it every which way and moving the arms up and down the posts trying to find a amicable placement to no avail.
04-08-2014, 07:07 PM | #83 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
| Re: Harley's Wrexo That's a pathetic reflection on BMRC if that's the case.
04-08-2014, 07:15 PM | #84 |
RCC Addict Join Date: Dec 2012 Location: Crookston
04-08-2014, 07:46 PM | #85 | |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: Harley's Wrexo Quote:
only as much as the EXO has. mine (the Bad Monkey) steer's just fine ! But - still have a little bump steer i am trying to get rid of. ill be up-dating the "Bad Monkeys" thread here soon !! so everyone can see what I've done | |
04-08-2014, 07:52 PM | #86 |
| Yeah I have bump steer to but not very much. Can't wait to see your updated. You have some sick builds.
04-08-2014, 07:55 PM | #87 |
| Re: Harley's Wrexo |
04-08-2014, 08:21 PM | #88 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: Harley's Wrexo
I've said it before and ill say it again. The dmg and lee are so right. Your putting a steering system from a go fast rig on a crawler, you can't expect it to have the same steering as a stock wraith. At worst you should get lock to lock on the knuckle. This will work for most things except difficult rock crawling. It's not a comp rig setup. I have a bmrc kit from the middle of production with the adapter plate for steering. I've got lock to lock on the knuckles and no bump steer that i can see with the bmrc titanium links. I had to cut the 2 rearmost holes that mount the upper plate to clear the bellcrank. I also flipped the crossbar on the bellcrank up to add clearance. From the comment made above about trimming ribs in the housing it sounds like white trash didn't put the spacers in that space the diff housing about 4-5mm from the top plate. This creates some of the spacing required to get the bellcrank to get full travel. Dna |
04-08-2014, 09:58 PM | #89 | |
I took the ribs off and clearanced the housing some to almost make it work. Today I cut the housing some more and made it work as good as my stock exo. Yes the spacers are in, and I still had to remove the rear mounting tabs for the diff so the steering rack could go all the way forward. The tie rods are still a bit long but I'll take it apart tomorrow and shorten the ends so it's not toe'd in. The kit isn't terrible but as Harley has already said, it almost seems like it was rushed to market without the steering being finished. Any kit that uses the traxxas rack will have bump steer due to the rack being too narrow compared to the stock center link. I was working on using the stock center link with the traxxas rack and widening out the mounting points on the upper plate using an add on piece like the old bmrc kit was updated with. | |
04-09-2014, 09:47 AM | #90 | |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Location Tri Cities??? | |
04-10-2014, 05:11 PM | #91 |
| Re: Harley's Wrexo
would an angled ball end help with the bump steer if you needed to get the links perpendicular with out pushing the steering bell crank so far forward?
04-11-2014, 03:29 PM | #92 |
Newbie Join Date: Jun 2012 Location: Mt Olive
| Re: Harley's Wrexo
I have the bmrc kit. Just trying to compile parts before i take my wraith apart. i was wondering if someone could give me a eye to eye length on the link from the servo to the bellcrank. I am using traxxas camber links for the camber links and the tie rods so that I can adjust all that once i get it done. i just need a length on that then I can find another traxxas link to work. Also, as a fix for the bump steer, try different lengths and positions of the camber links to get it to a minimum. Also can someone that has used the mip mod show and/or tell how much they had to grind out of the aluminum caster blocks to get enough clearance for the steering angles to be decent. cant wait to get this thing going. thank you in advance for any info!!
06-21-2014, 10:12 PM | #93 |
Newbie Join Date: Mar 2013 Location: Australia
| Re: Harley's Wrexo
Hey harley Now axial are releasing the yeti will you finish this? Or just get a yeti and put the wrexo bits and pieces into something else? Haha |
06-22-2014, 12:43 PM | #94 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
I was wondering the same thing
06-22-2014, 10:01 PM | #95 | |||
Dna | |||
Harley's Wrexo - Similar Threads | ||||
my wrexo | Frakke | Videos! | 5 | 08-27-2013 12:27 AM |
