Thread: Szczerba's 2.2 CXT
Old 10-24-2013, 07:56 AM   #101
Default Szczerba's 2.2 CXT
Originally Posted by 67mustang View Post
For a rig with that kind of weight, i think 10:1 gearing is a wise choice. I have run mine with a few different kv motors for certain top speeds and whatnot. I think 10:1 for gearing is the right setup, the only question is what top speed you are happy with. Whether you use a 3-4k kv motor or a 1000kv motor, 3s or 4s...the gearing choice is right in my opinion. I dont think a truck like this should go very fast anyway. Does your 64t spur fit with the stock outputs and mips?
The 10:1 setup is for crawling because the top end is not that great. It will move some rocks around though. I can make a pinion swap in under 10 minutes though. I bought a longer RC4WD 11tooth 32p for a little more top end, if the terrian allows.
Believe it or not, this truck can handles speed good. The rear sway bar, correct suspension geometry and weight distribution are the key factors for the good handling.
64t spur does not fit with the short Crawler Innovations 5mm output. If I put the long CI output up front, it would.
Originally Posted by Manning View Post
Wow, look at that nut on the slipper! Looks like a beaver with a chipped tooth gnawed on it. Or maybe pliers were used for an emergency fix during a run......
Shout out to my pit crew, Team Manning.
I now have dual Carter Fab & Machine » Wheel Nut Lock Kit . The slipper takes alot of force with this beast.
Szczerba is offline   Reply With Quote
Old 10-29-2013, 04:34 PM   #102
Wheel and tire dress up the other day with my SLW modded clod wheels and shaved Rumbles made for my first MT build last year.
Sent from my computer-phone.
Old 11-14-2013, 01:53 PM   #103
Default Re: Szczerba's 2.2 CXT
Originally Posted by MCW24 View Post
This thing is wicked, I want one!!
great job
Thanks. It was fun to build and fun to drive.
Here is it's bigger brother. Szczerba's Tow Rig
Old 11-23-2013, 06:41 PM   #104
Took this rig out to run the ARCC Zombie G6. Just ran it for fun after I ran my 1.55 rig.
Took me about 45 minutes to get through the course after bypassing a few gates here and there that were tok narrow. Like between trees, etc.
The motor was not even warm! This rig crawls great and is alot of fun!
Couple pics.
Old 11-23-2013, 08:32 PM   #105
It's funny to hear it coming down the trail. The sound matches the size.
mmatthews is offline   Reply With Quote
Old 11-23-2013, 10:08 PM   #106
Definitely not going to sneak up on anyone with that Holmes Hobbies beast whaling down the trail.
Old 11-23-2013, 10:16 PM   #107
Charlie coulda put his mini bastard on the back of it...
its a site to behold...and hold..
as big as it is it wheels awesome!
ROLANDROCKSHOP is offline   Reply With Quote
Old 11-24-2013, 02:17 PM   #108
Thanks mang. I was kinda surprised the motor wasnt hot after 45 plus minutes of trailing and full throttle dirt road blasting. Motor wasnt even warm. Still geared 6/60.
And no broken parts!
Old 12-04-2013, 01:17 PM   #109
Got some Duece's Wild single stage foams from Eddie at Crawler Innovations. I think they will be perfect for this 15lbs rig.
I was running 5.25" Crawler Innovations Double Deuce Foams with firm outers.
I got the 2.2 talls and the 2.2 standard. Mounting up the standards for these swampers.
Old setup on top new standard setup on bottom. New setup squares the tire up good.
Old setup on top new setup on bottom. New setup holds the weight alot better with not tire squat. Tough to see in the picture but the old setup had a good amount of tire squat.
Old 12-04-2013, 06:08 PM   #110
Originally Posted by gillbily23 View Post
This is a sweet rig, very nice work!
Thanks the new single stage foams are going to wake it up on the rocks.
Szczerba's 2.2 CXT - Similar Threads
Szczerba's 2.2s Villian Szczerba Axial AX-10 Scorpion 75 10-17-2013 05:38 PM
Szczerba's FF-SZ 2.2s Szczerba Axial AX-10 Scorpion 389 06-11-2013 08:30 PM
Szczerba's JK (Minus some doors) Szczerba G-Made Crawlers 193 11-06-2012 07:26 AM
szczerba's saftey video ROLANDROCKSHOP Scale Videos! 10 05-25-2012 08:21 AM
szczerba's f-toy ROLANDROCKSHOP Scale Videos! 4 05-24-2012 09:12 AM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
