09-30-2013, 03:49 PM | #21 | |
| Re: Apparently "Ultra" wasn't enough Quote:
09-30-2013, 04:02 PM | #22 | |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
I agree that in some cases the VP links could cause limitations to your steering. This very much depends on your back spacing, tires, and tie rod setup. In snicklefritz's case I don't see there being an issue. On a normal mounted tie rod the ends are going to hit the c hubs before the tire comes into contact with aftermarket wheels. In my own case my tires just hit the lower links at the same time the nut that holds on my tie rod hits the c hub(I run mine with the tie rod above the steering arms) I have my steering end points to stop just before this point, so it is a minor issue. | |
09-30-2013, 04:10 PM | #23 | |||
Since 10/26/12, see post #63: Natedog's Wraith Kit Build now with Cage Mods Quote:
Anyways nice looking build start, just trying to help. Last edited by Natedog; 09-30-2013 at 04:19 PM. | |||
09-30-2013, 06:09 PM | #24 |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
I didn't see any thread jacking, just a little healthy controversy caused by me putting my links on wrong (according to VP). Anyways, I appreciate any and all input. Thanks, guys.
09-30-2013, 09:14 PM | #25 |
The motor is gonna fit after a little trim to the upper link mount. I won't need to remove much plastic at all.
09-30-2013, 11:08 PM | #26 |
My straight links never bind I'm fitting a big motor with lots of trimming so I'm sure that will go in with little hassle Last edited by evan03; 09-30-2013 at 11:29 PM. |
10-01-2013, 09:21 AM | #27 |
That's a big boy. What motor are you running, Evan?
10-01-2013, 09:08 PM | #28 |
Quarry Creeper Join Date: Sep 2011 Location: hemet
Got her running yet?
10-01-2013, 10:21 PM | #29 |
Turnigy 2100 kV 1/8 scale motor. Comparable to tekins t8. Crazy power on 5 and 6s. I built this rig for sand. Just happens to crawl decent on low voltage. Pretty good rock bouncer on 4s Last edited by evan03; 10-01-2013 at 10:26 PM. |
10-02-2013, 05:29 PM | #30 | |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
I wish I had something like that near from me, SCT and buggy races dont interest me much but this rock racing thing seem so cool!! congrats | |
10-02-2013, 06:13 PM | #31 |
Newbie Join Date: Aug 2013 Location: bellevue,oh
Will those shocks give you the travel range you'll need? They seem short?
10-02-2013, 07:57 PM | #32 | |
The slash rears may be longer, I should go check . . . Last edited by snicklefritz; 10-02-2013 at 07:59 PM. | |
10-02-2013, 08:25 PM | #33 |
I thought the shocks looked perfect for the style build this is. Honestly most of us running longer shocks then needed |
10-03-2013, 11:32 AM | #34 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Apparently "Ultra" wasn't enough |
10-03-2013, 12:34 PM | #35 |
oh Dana Delany.
10-03-2013, 01:34 PM | #36 |
I got the motor to fit last night. The trim job doesn't look to bad, either. I'll get some pics up tonight. I just need to get my bec wired in and procure a 32p pinion for a 5mm shaft. Stupid me didn't think about that when I made my last order at RPP, I got two pinions for 1/8" shafts though! Hopefully Hobbytown has some in stock. You never know with those people.
10-03-2013, 10:17 PM | #37 |
They probly will since some traxxas stuff runs 5mm shafts
10-04-2013, 09:13 AM | #38 | |
They had one 12 tooth. My 14 should be showing up in the mail today so I should have a good range of possible ratios. Hopefully I have some time to test. Race is tomorrow. | |
10-04-2013, 11:24 AM | #39 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
You won't be the only person testing on race day. Good luck, and see ya there.
10-05-2013, 08:33 AM | #40 |
Good luck at the race
Apparently "Ultra" wasn't enough - Similar Threads | ||||
Crawler Innovations "Top Shelf" Ultra 4 | Nova's Ark | 1.9 Scale Rigs | 100 | 06-01-2018 10:31 PM |
Gear Head RC "Trail Torch" Ultra Bright LED Light Bar | Gear Head RC | Vendors Electronics | 0 | 02-04-2012 11:14 AM |
Dinky R/C's Ultra 4400, "The Muddauber" | muddauber7 | 2.2 Scale Rigs | 23 | 09-03-2011 05:49 AM |
