10-04-2013, 02:58 PM | #1 |
Newbie Join Date: Apr 2013 Location: So Cal
| Gearing Help
Just ordered a MMP speed control and a Tekin ROC 412 3100kv motor what is a ball park for the pinion and spur gear to me going, also how long will the stock drive shafts hold up
10-04-2013, 03:39 PM | #2 |
A fair ratio at the pinion/spur is near 6:1, preferably 32p. The driveshafts won't last long with that combo. An insert in the male end will make it last a bit longer but will also possibly impede maintenance.
10-04-2013, 03:49 PM | #3 |
| Re: Gearing Help
You will want to run 32p for the Spur and Pinion. I went with a SuperShafty Beefy Top shaft with the RPP #7856 Slipper 56T with 12T Pinion. I started out with a 54T 32p plastic spur but I broke the stock top shaft after a couple of packs. The stock drive shafts didn't last much longer even with the drive shaft mod. |
10-04-2013, 05:21 PM | #4 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
| Re: Gearing Help
I am running the 54t traxxas slash spur gear and a 14t pinion (32p is a must) No problems so far while running my 19t motor. However i did twist a driveshaft after about 12 packs through it. (probably half my fault) lol |
10-04-2013, 07:17 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Gearing Help
Another option would be the steel slipper/spur from RRP in 48 pitch. I run my pro4 3300 at around a 5:1. But could go all the way to4:1 just keep an eye on temps.
10-04-2013, 10:10 PM | #6 |
| Re: Gearing Help
Depending on the weight of the rig and tire size, with the Roc412 3100 56/10-11 is a good place to start. If it still gets a little warm start playing with different pinions and maybe a different spur.
10-05-2013, 07:56 AM | #7 |
Rock Crawler Join Date: Aug 2010 Location: Esko
I have the pro4 3300 in mine and run 56/14 with no problems. I run 2.2 tsl tires on aluminum wheels and it all runs pretty cool. Not sure on my weight though. I'm guessing 1.5 pounds more than stock maybe.
10-07-2013, 11:37 PM | #8 |
| Re: Gearing Help
Anybody have the part number the the steel spur/slipper I need the 56 tooth one
10-08-2013, 02:43 AM | #9 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Gearing Help |
10-08-2013, 10:11 AM | #10 | |
| Re: Gearing Help Quote: | |
Gearing Help - Similar Threads | ||||
gearing...? | mhflies | General Crawlers | 1 | 07-24-2012 09:53 PM |
Gearing | Steve182 | Tamiya CR-01 | 6 | 09-26-2008 10:09 PM |
1.9 wk gearing? | bigblazerboy | General Crawlers | 2 | 02-18-2008 05:31 PM |
1.9 gearing? | bigblazerboy | HPI Wheely King | 2 | 02-17-2008 12:47 PM |
