10-31-2013, 06:08 PM | #1 |
Pebble Pounder Join Date: Sep 2013 Location: Mechanicsburg, PA
| Hot Racing axle widener hub extension
I am running the stock Wraith kit wheels. I noticed that the RcBros knuckle weights will rub on the inner back side of the wheel. I thinking getting a 10mm hub axle extension will give me the clearance I need. The hub nut is 12mm and 5.5mm long. I am looking at getting the Hot Racing multi-width hex adapters fit kit. Does anybody know if this will HR kit will work to widen the front so I can run the RcBbros knuckle weights yet still run the stock wheels? Thanks |
Hot Racing axle widener hub extension - Similar Threads | ||||
Hub Extension problem? | whitefox2020 | Traxxas Crawlers | 0 | 08-24-2012 05:23 PM |
hot racing axle gearing | Wicked_Jester | General Crawlers | 7 | 01-26-2010 08:03 AM |
Hot racing 12mm to 17mm adapter/widener | ecoli | Tamiya Clod Buster | 6 | 03-08-2009 02:44 PM |
Hot Racing straight axle kit, bent axle shaft | sierradmax | Axial AX-10 Scorpion | 6 | 09-07-2008 01:04 PM |
