09-19-2013, 09:07 AM | #1 |
| Szczerba's 2.2 CXT Objective: Make a 2.2 Rig to run in the Sept 28 Recon G6 in Hot Springs, AR Body: 1/6th Scale CXT Cab Chassis: Built by me Wheelbase: 17.5" Axles: Plastic Wraith Axle Cases HD Axial Gears GripFab Stainless Steel Lockers Axial Lower Link Mounts Vanquish Wraith Chubs C-Hub Vanquish Wraith Steering Knuckles Vanquish Titanium Tie Rods RC4WD ARB Diff Cover for Wraiths Axial universal's "Dinky Link" S-Type (Front) Stock Wraith Rear 4-Link Transmission: Vanquish Aluminum Axial Transmission Supershafty.com one piece motor mount Axial Spur Cover Crawler Innovations 4340 steel; 5mm - Axial Trans Output Pair MIP Driveshafts. Cut, chopped, rebuilt. 32 pitch gears 54-60t 15-20t pinions Shocks.. 4" Bigbores with Revo rod end mod (for now) Links.. Vanquish Ti Uppers and Lower Links Electronics: ESC: Mamba Max Pro Motor: Tekin Redline 13.5 (For Now) Servos: Hitec 7950th BEC: Castle Creations Battery: Valuehobby.com 3s Lipo Wheels/Tires/Foams.. Wheels: TSS Rockrawler 2.2 wheels modded for SLW Hubs Tires: Proline 2.2 TSL's Hubs: Vanquish 225 SLW Foams: Crawler Innovations/2.2 Double Deuce Foams Last edited by Szczerba; 09-19-2013 at 12:12 PM. |
09-19-2013, 09:12 AM | #2 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Szczerba's 2.2 CXT J |
09-19-2013, 09:26 AM | #3 |
| Re: Szczerba's 2.2 CXT This is too. Ripping 1" square for chassis rails. Good ol' drill press, manrel and 3" cutoff wheel. |
09-19-2013, 09:37 AM | #4 |
| Re: Szczerba's 2.2 CXT |
09-19-2013, 09:37 AM | #5 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
09-19-2013, 09:41 AM | #6 | |
| Re: Szczerba's 2.2 CXT Quote:
When I got about halfway through the second side the cut side was flexing around a bit. I thought about tacking the already cut side back together real quick but that was too much effort and kept cutting. Black paint is my friend. Indeed. Tuckin' 2.2's. shown with 450 hubs. 225 hubs are on it now. | |
09-19-2013, 09:45 AM | #7 |
first chassis iteration I mocked it up and thought to myself. "Oh yea, geometry does matter on 1:10scale rigs too. Let try again" |
09-19-2013, 09:52 AM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
glad that big body finally found a home.... it was taking up my project space.. |
09-19-2013, 09:54 AM | #9 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
What's your plan for a bed?
09-19-2013, 10:12 AM | #10 |
It may be over the top but that thing would be bitchin with big stacks and a smoke machine.
09-19-2013, 10:12 AM | #11 |
09-19-2013, 10:13 AM | #12 |
09-19-2013, 10:34 AM | #13 | |||
Simple flatbed with a headache rack and spares. You wouldn't wanna see my styrene box making skills. Quote:
Additional doggy weight is not included in the race day truck setup spec sheet. Toby stays in the pits. | |||
09-19-2013, 11:29 AM | #14 |
2nd Chassis setup. Meh.
09-19-2013, 12:26 PM | #15 |
3rd chassis setup. Mucho betterer. Snuck some Mattzilla 3 hole tabs on the subframe. 3 holes of upper link adjustment. Lower cross bar is just sitting in place for now. Trans mount made. Sent from my thumbs. |
09-19-2013, 01:57 PM | #16 |
I chop, therefore, I am. Ignore the lower subframe brace not welded in. Cab is just chillin on the rails too. |
09-19-2013, 02:04 PM | #17 |
It would make a cool t5 support truck.
09-19-2013, 02:04 PM | #18 |
I find that I keep wandering into this thread, I can't wait to see how it turns out.
09-19-2013, 02:12 PM | #19 | |
| Re: Szczerba's 2.2 CXT Yea, Dakar kindish, G6 pull out rig, etc. Quote:
I started last week and have been taking photos along the way. I am out of pictures as of now. I have cut and rewelded the MIP's to 6" for the driveshafts. Used 3/8", 0.04"something walled tube. Next up is shock hoops and body mounting. Probably going to hinge the body up front with a small 5/32" rod frame. 1/4" and 3/8" tube should be at the house now for the sliders, headache rack and bed. | |
09-19-2013, 05:13 PM | #20 |
Upper link mounts mocked up. Ghetto fabbin Sent from my thumbs. |
Szczerba's 2.2 CXT - Similar Threads | ||||
Szczerba's 2.2s Villian | Szczerba | Axial AX-10 Scorpion | 75 | 10-17-2013 05:38 PM |
Szczerba's FF-SZ 2.2s | Szczerba | Axial AX-10 Scorpion | 389 | 06-11-2013 08:30 PM |
Szczerba's JK (Minus some doors) | Szczerba | G-Made Crawlers | 193 | 11-06-2012 07:26 AM |
szczerba's saftey video | ROLANDROCKSHOP | Scale Videos! | 10 | 05-25-2012 08:21 AM |
szczerba's f-toy | ROLANDROCKSHOP | Scale Videos! | 4 | 05-24-2012 09:12 AM |
