11-25-2013, 09:44 PM | #61 | |
| Re: Wraaaaaaaaith Quote:
I'm going to run it tomorrow with and without the mod and see what I like best. Rough AS numbers are 125% stock, with instant center right below the COG, 85% as modified with instant center 4" or so ahead of the axle centerline. Last edited by Duuuuuuuude; 11-25-2013 at 09:47 PM. | |
11-25-2013, 09:47 PM | #62 |
| Re: Wraaaaaaaaith
It should make that front end less "light" on verticals. Of course overall rig weight plays a part in that effect too. Corkysk8 modified his SCX frame at the rear uppers like I did and said there was an immediate performance increase ... |
11-26-2013, 01:21 AM | #63 |
| Re: Wraaaaaaaaith
I don't understand what raising the upper links does. In the 1:1 world they should be psrralell
11-26-2013, 06:20 AM | #64 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Wraaaaaaaaith
This is just what I needed! You to get your hands on this wraith platform and give it the geo fix it needs! Paypal ready for your front lower link mounts! |
11-26-2013, 07:19 AM | #65 |
| Wraaaaaaaaith |
11-26-2013, 07:43 AM | #66 |
| Re: Wraaaaaaaaith |
11-26-2013, 07:56 AM | #67 |
| Re: Wraaaaaaaaith
This link will give you insight into what I'm doing, and why you shouldn't make direct crossovers from 1:1 to 1:10ish rigs. Hard to believe its been almost 2 years... Diagram for Anti-squat |
11-26-2013, 08:21 AM | #68 | |
Very rarely will you find links running parallel in the buggy/wheeling world. Drag cars and mega trucks yes, but the geometric needs are different when you build suspension to climb. Coupling these sweet raisers with raising the upper links at the axle will make the rig plant the rear harder than it does stock. | |
11-26-2013, 08:59 AM | #69 |
Now get to making an scx version that can clear the trans My cheap perforated alum pieces look like shat. |
11-26-2013, 09:09 AM | #70 |
| Re: Wraaaaaaaaith |
11-26-2013, 09:12 AM | #71 |
| Re: Wraaaaaaaaith
11-26-2013, 09:23 AM | #72 |
| Re: Wraaaaaaaaith |
11-26-2013, 09:34 AM | #73 | ||
11-26-2013, 10:44 AM | #74 | |
Its all a compromise of instant center and center of gravity, anti squat and lift. The perfect geometry doesn't exist that will work for everyone so you have to find the combo that works for your driving style. While it is hard to find a link setup that works for everyone it is easy to find one that sucks for everyone. Wheelie king and ax/scx Y upper strIght lowers come to mind. The wraiths dual triangulated setup is light years ahead in all areas. But there is always room for improvement and tuning to fit individual needs. | |
11-26-2013, 10:55 AM | #75 | |
Duuuuuuuuude is a smart feller and will do the hobby good with his little pieces he can make to address the above stated issues. I have spent hours of welding to correct my rigs. | |
11-26-2013, 10:55 AM | #76 |
| On my c3, there's no option to flip the trans. Too much crap up front, actually everything is in front besides rx & winch controller. Probably better to model it off of a stock rig to make it friendly but design in such a way that other guys can make fit, if that makes sense. Keep bugging him about it |
11-26-2013, 11:10 AM | #77 |
| Re: Wraaaaaaaaith |
11-26-2013, 01:22 PM | #78 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Wraaaaaaaaith
sweet deal! Im in for set when you get ready! Been waiting on someone to tackle this... |
11-26-2013, 01:51 PM | #79 | |
11-26-2013, 04:44 PM | #80 |
| Re: Wraaaaaaaaith
Got to run a couple of packs through, and I have to say, I am really impressed with the Wraith. For a nearly box stock kit build (tires and foams too) with no added weight it does really well at both crawling and bombing around. Very capable. Pack one was stock geometry. It did good, better than I had expected. Pack two was with the proto suspension mounts, plus a pair of tie-ins I made just to reinforce the skid so it wasn't being tweaked around as much. It did better. Not omfg better, but a more stable, flatfooted, subtle kind of all around better. I've got video to edit, but the wife has the laptop until late tonight. May not be able to upload until really late or tomorrow. Otherwise I think its going to be a winner. |
