Thread: Robinson racing steel slipper question
Old 11-20-2013, 07:40 PM   #1
Default Robinson racing steel slipper question
I read in some posts from a year or so back that when adding the robinson racing steel slipper kit that you also had to buy the slash slipper rebuild kit for just the spring and nut. Is this still true. I ask because when looking on the supershafty site the kit looks like it includes the spring and nut. Also it is required to have the beefy top shaft... I see it comes with a spring and nut as well.
So are those the only two things require or do u still need the rebuild kit?
Thanks
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Riddler6.7 is offline   Reply With Quote
Old 11-21-2013, 10:53 AM   #2
Default Re: Robinson racing steel slipper question
If you buy the 32p unit I believe you have to have the super shaft top shaft. It is a little bigger/longer I think. But if you use the 48p unit you don't need anything else.
hatefulboy is offline   Reply With Quote
Old 11-21-2013, 11:33 AM   #3
I already bought all 32p gears for future proofing. But the spurs are plastic. Just planning for when I fry the two plastic spurs
Old 11-21-2013, 04:42 PM   #4
Thanks
You just need the Beefy Top Shaft and the Robinson Racing 32P Slipper Kit Steel Slipper(56T). The Beefy Top Shaft comes wit the spring and the nut.
k7zpj is offline   Reply With Quote
Old 11-21-2013, 05:14 PM   #5
Cool thanks
Robinson racing steel slipper question - Similar Threads
Robinson Racing Gen3 Slipper Unit cmnyj28 Axial Wraith 18 06-19-2014 07:11 PM
question for you all on the Robinson racing slipper? champ198 Axial Wraith 8 07-04-2013 07:09 AM
Robinson Racing steel slipper spur rubbing t3yf5g Axial Wraith 12 08-04-2012 09:37 PM
Converting To a Robinson Racing Slipper Clutch tractionaction Axial SCX-10 0 06-15-2012 04:56 AM
robinson racing slipper 48p kmas Axial Wraith 3 05-11-2012 11:08 PM
