11-25-2013, 11:55 PM | #21 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: overdrive gears.?
I have a 6lb scx10 using a 27T mod motor and a 2s...when the gear breaks ill make the upgrade or go back to stock depending on how long they lasted me from normal use. Was hoping I could use a 14T HD pinion with a HD stock tooth count ring gear....now im bummed out...lol |
11-26-2013, 01:00 AM | #22 |
Well ummmm...im thinking I had this backwards...a 14T to replace a 13T would overdrive not underdrive.. |
11-26-2013, 06:00 PM | #23 |
Combination of beer and android auto correct
11-27-2013, 04:32 AM | #24 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
I was using OD front and UD in rear with no issues. It helped a lot with steering and crawling but I wanted a little more speed so I just put 36/14 gears in the rear as well.
11-27-2013, 05:40 AM | #25 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
Well im back to stock on fr/rr. I'll giva an update soon, thanks for the info, rolls smoother now than with the od gears. i put the od's in my dedicated crawler. hittin our new Ultrta4 here in Panama City this afternoon. so ill have a vid to put up. anybody close to here should come out and see the track. always there 3rd sat. of the month. |
11-27-2013, 07:07 PM | #26 | |
| Re: overdrive gears.? Quote:
outside temp 47 slow but ok crawling, but still acted over geared. would get stalled easier than I expected. I guess used to 3s power but anyway it held an ok temp finger 5 count seemed faster in reverse,but half way thru the the pack the temps were rising bad and stalling happened more often. But reverse would work fine. i would try a gate in forward and stall out. try the same gate in reverse and power right thru. temp stayed finger 2 count and smelled that burn, i ran it hard in reverse and seemed like the temps dropped a little but fingers were numb so who knows. temp gun batttery dead so... so i checked my manual and the diffs are installed correctly I flipped them any way and will see what happens. I read alot where flipping was needed due to backwards from the manual Read some things where clockwise and counter clockwise motors ETC. so this is my update.....................Until later | |
11-27-2013, 07:57 PM | #27 |
Sounds like your running either the motor backwards, or with negative timing. This will cause excessive heat. When you roll the truck forward, which way does the pinion gear on the motor rotate, as looking at the gear side of the motor? |
11-27-2013, 08:53 PM | #28 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
If I were you, I would pull the trans, remove the motor and spin the trans with your fingers. See if something is dragging. Then do the same for the axles. I suspect you have something not spinning as freely as it should and creating drag and heat.
11-27-2013, 09:04 PM | #29 | |
Clockwise now, I'v flipped it | |
11-27-2013, 09:08 PM | #30 |
| Re: overdrive gears.? |
12-04-2013, 05:01 AM | #31 |
Ok do i changed up to a stock 2ot motor &13/87. Now she seems to run cool with lots of Power. I do have this one hill that does seen to eat motors tho, but, it's probably because it's a hard hill to climb.
07-01-2020, 01:28 AM | #32 |
Newbie Join Date: Nov 2019 Location: ENUMCLAW
I did underdrive in the rear of my wraith I have a 5 slot 16t motor and after 5 min it's smoking hot... I can't think of any other reason but the ender drive gearing... I would like to figure this out however I'm dropping in a HH trailmaster pro 2200 in her tomorrow!!! so my GOM build will get the HH 16T Brushed setup and see if it's smokes it too... would having overdrive in the front help balance the UD in the rear out a bit? this was a good topic and conversation. thanks for the info |
overdrive gears.? - Similar Threads | ||||
UnderDrive and OverDrive Gears???? | AsILayDying | Axial SCX-10 | 79 | 09-13-2014 07:46 PM |
overdrive gears | crawler pilot | Losi Mini-Rock Crawler | 13 | 11-29-2009 04:23 PM |
