01-25-2014, 12:52 PM | #1 |
Pebble Pounder Join Date: Sep 2007 Location: Lowell
| Wraith hr links junk any fix for them?
Mods can delete thanks for the tips guys Sent from my I wait for it ...Phone using Tapatalk Last edited by sanny632; 02-09-2014 at 09:58 AM. |
01-25-2014, 05:30 PM | #2 |
Quarry Creeper Join Date: Oct 2010 Location: denver
| Re: Wraith hr links junk any fix for them?
You could try new rod ends, if that won't do it replace em!
01-25-2014, 05:32 PM | #3 |
Nitro fuel tubing on either side will help a little.
01-25-2014, 06:13 PM | #4 |
They are one solid link can't replace rod ends :( Sent from my I wait for it ...Phone using Tapatalk Last edited by sanny632; 02-09-2014 at 09:58 AM. |
01-25-2014, 06:14 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: vincennes 2 hours south of indianapolis
If the rod ends are replaceable use some traxxas ends. If they are fixed length use the plastic balls from the wraith links for the time being
01-25-2014, 06:15 PM | #6 |
Tet
01-25-2014, 07:17 PM | #7 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
You can use a couple small sockets and press the socket a bit tighter. I bought a used wraith with some generic links on it. The pressed in side of the socket came apart and the ball fell out. a little holding locktight and some small sockets (7 or 8mm) and I pressed it back into working. Tossed them shortly after that. |
01-25-2014, 07:29 PM | #8 |
RCC Addict Join Date: May 2008 Location: Southern,WV
A small O-ring on each side of the ball.
01-25-2014, 07:29 PM | #9 |
Thanks Sent from my I wait for it ...Phone using Tapatalk |
02-07-2014, 04:21 PM | #10 |
Rock Stacker Join Date: Jan 2014 Location: Reseda
I JB Weld-ed the brass retainer rings, and cut some o rings out of nitro fuel tubing and placed the on both sides of the ball. These are crappy links, I have since replaced them with Axial stage 1 links, and used the HR tubes to make a custom drag link and extended steering column.
02-07-2014, 08:54 PM | #11 |
Pebble Pounder Join Date: Dec 2013 Location: Keller
we used locktite
Wraith hr links junk any fix for them? - Similar Threads | ||||
Floppy rear links,, simple fix | The Real Dogman | Vaterra Twin Hammers | 1 | 03-30-2013 06:38 AM |
How do you fix Wild Willy into your Wraith? | Badboy_207 | Axial Wraith | 8 | 06-30-2012 05:42 PM |
Making DIY links, but all you can find is coated brake line? Easy fix with a Dremel! | iamsuperbleeder | Tools, and Procedures | 7 | 08-14-2011 01:34 PM |
