02-12-2014, 02:12 PM | #21 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Fed and state refunds are in. Beef tubes ordered, skid plates ordered, kit ordered. Still to go. Steering servo, motor Last edited by DrDiff952; 02-27-2014 at 10:51 PM. |
02-13-2014, 11:41 PM | #22 |
DMG Skid Plates should be here Friday along with my beef tubes, TX/RX on Saturday. Kit should be here Monday. I will install the beef tubes and skid plates, as s I build the kit. Steering Servo, Bead locks, and motor are TBD. Last edited by DrDiff952; 02-14-2014 at 05:41 AM. |
02-14-2014, 05:45 AM | #23 |
Let me know how the beef tubes work out..
02-14-2014, 03:18 PM | #24 |
Kit and beef tubes are here, DMG skid plates were supposed to be here. Maybe tomorrow.
02-15-2014, 08:12 PM | #25 |
DMG Skid Plates arrived. Now to find some free time for the build
02-15-2014, 10:44 PM | #26 |
| Re: DrDiff952"s O.P.A.A.T. Wraith
how is the quality and weight of the DMG skid plates?
02-16-2014, 06:12 PM | #27 |
Got thr TX/RX today. I just can't find the time to build. :(
02-17-2014, 08:53 AM | #28 |
Dig Kit should be here later today, bead locks should be here in 2-3 days
02-17-2014, 10:39 AM | #29 |
That's great!...ya just have to steal time to build lol. I ended up changing out the links on my green 1.9 wraith last night. It changed the wheelbase from 12.5 inches to 14 inches. It makes it much more stable now.
02-18-2014, 12:24 PM | #30 |
| Re: DrDiff952"s O.P.A.A.T. Wraith Last edited by DrDiff952; 02-18-2014 at 12:55 PM. |
02-18-2014, 01:43 PM | #31 |
Ok got a motor. Now the only thing left is the steering servo and servo arm. Thinking about a Savox SA 1231SG. 0.14 seconds and 444.4 @ 6.0 volts.
02-18-2014, 03:14 PM | #32 |
thats a good choice I think.. i am thinking of getting that one for a spare
02-18-2014, 09:23 PM | #33 |
Ordered that savox servo
02-19-2014, 01:20 AM | #34 |
The bead locks came in today, I was expecting DIG components. So, the white dot ripsaws were mounted on the 2.2 Rockster bead locks. Then wheels and tires were put on the axles. I then started on the transmission. Ran into a problem when the motor's output shaft was too long for the gear cover. Decided that was enough for one night. Got rid of a bunch of plastic. Still can not find my DIG components. sorry no pictures, I am tired.
02-19-2014, 07:55 AM | #35 |
Well as luck would have it, the DIG came yesterday as well. Both packages came while I was at work, I only saw one.
02-19-2014, 08:32 AM | #36 |
I have ran into the issue of the shaft being too long for the cover before...I put the cover on by hand and pushed on it fairly hard to mark the cover, then drilled a hole to let the shaft go thru the cover. The duratrax Baja Bug I have I just held the cover on with the battery in and the Bug turned on, hit the trigger and in about 5 seconds the shaft bored its own hole making a perfect fit and pretty water tight as well.
02-21-2014, 01:10 AM | #37 |
Well I got some more time in today. Built the link bars, drive shafts, steering linkages, and mounted the axels to the center section transmission. Could not get the final connection to the rear pumpkin on the rear axel. If I bolt it to the rear pumpkin I can not make the transfer case connection. If I make the rear transfer case connection, I can't connect at the pumpkin.
02-21-2014, 10:17 AM | #38 |
What is the problem? Shafts too short or holes don't line up? There are 3 different lengths of shafts in the kit I think.....
02-21-2014, 10:57 AM | #39 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
Take some pics of the parts and situation, will help us make sense of it Sent from my SGH-T889 using Tapatalk |
02-21-2014, 02:25 PM | #40 |
| Re: DrDiff952"s O.P.A.A.T. Wraith |
DrDiff952"s O.P.A.A.T. Wraith - Similar Threads | ||||
Wraith "Time Killer" | OORRACING | Axial Wraith | 0 | 11-08-2013 11:20 PM |
one piece at a time | foproy | Tamiya Clod Buster | 58 | 06-07-2010 01:36 PM |
