07-17-2014, 06:19 AM | #141 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Board is exchanged, radio is hacked. Now to set up a three position switch for the Dig
07-18-2014, 04:55 PM | #142 |
| Re: DrDiff952"s O.P.A.A.T. Wraith
Radio is programmed, I have to adjust endpoint travel to keep the servo arm from moving when the servo travels.
07-22-2014, 06:32 PM | #143 |
I just bought a front axel complete with Axial universals. So I will have to flip it around, pull the locker and flip it to give the O.P.A.T. 4WS
07-24-2014, 11:41 PM | #144 |
Took a break from trying to program the radio. I did some body work. Excuse my lack of scale Then I attacked the hood lines to open the hood. No more removing the whole body just to change a battery. I can sympathise with Poison Spider owners! |
07-25-2014, 07:50 PM | #145 |
Now that the FSFT-3C ois hacked and programed for $WS, I Bought a complete front axel with Axial Universals. I rebuilt it into a rear axel with rear steer. Yes I know I have to use the rear axel truss and DMG rear skid plate off the rig but it is ready to be mounted on the rig. I am waiting on a servo, arm, and links. Last edited by DrDiff952; 07-25-2014 at 07:56 PM. |
07-28-2014, 04:31 PM | #146 |
I couldn't find a working servo to test it so. I unpluged the 1.9 steering servo and pluged it into a couple of y harneses and finally into the RX of the O.P.A.T. My 4WS WORKS! I am uploading video to YouTube as I type this. I will post video ASAP. |
07-29-2014, 04:45 AM | #147 |
| Re: DrDiff952"s O.P.A.A.T. Wraith Last edited by DrDiff952; 08-04-2014 at 06:55 PM. |
07-31-2014, 01:21 PM | #148 |
Well I went crazy today. Bought another servo, steering link set, and even won a mamba maxx pro. The idea is for the mamba to power the DIG servo and the ESC. While the two steering servo's will be powered by the BEC. |
08-02-2014, 12:43 PM | #149 |
| Re: DrDiff952"s O.P.A.T. Wraith
Got the Savöx 1231SG and Vanquish Titanium steering links. Waiting on the ESC.
08-03-2014, 11:09 AM | #150 |
Axel and servo installed so a test is in order.... Last edited by DrDiff952; 08-04-2014 at 06:57 PM. |
08-05-2014, 07:37 PM | #151 |
My Mamba Max Pro came in a day early. Unfortunately the sensored brushless motor I wanted is back ordered. I want to rig up an adapter harness to connect up a brushed motor as the MMP can do Brushed or Brushless.
08-05-2014, 08:10 PM | #152 |
I am thinking of using a Y harness in reverse. Connect the BEC output directly to the Y harness And then remove the signal wire (brown / white). Then I will solder these to the red and black wires on the servo harnesses. Thus only the Servo Signal wire will connect to the RX |
08-07-2014, 12:32 PM | #153 |
I am starting to think more and more about getting a second MMP to power this rig and put this MMP into the 1.9 Weekend Warrior Wraith!
08-07-2014, 12:37 PM | #154 |
Do it! You know you want to lol
08-14-2014, 02:51 PM | #155 |
| Re: DrDiff952"s O.P.A.A.T. Wraith |
09-08-2014, 02:27 PM | #156 |
Got some scale plates... |
12-26-2014, 11:47 PM | #157 |
Took the rig to Coffee Creek Watershed and played broke a rear c hub. Everyone loves the 4WS
12-27-2014, 06:43 AM | #158 |
It was a nice day to crawl! gotta do it again
12-27-2014, 09:06 AM | #159 |
Carnage form Coffie Creek Watershed run. C Hub replaced but will need a new U-joint |
DrDiff952"s O.P.A.A.T. Wraith - Similar Threads | ||||
Wraith "Time Killer" | OORRACING | Axial Wraith | 0 | 11-08-2013 11:20 PM |
one piece at a time | foproy | Tamiya Clod Buster | 58 | 06-07-2010 01:36 PM |
