02-08-2014, 04:08 PM | #1 |
Rock Stacker Join Date: Jun 2013 Location: watertown
| Knuckle weights
I'm having trouble finding any knuckle weights for my wraith I know vanquish makes a set for xr10 but they are fairly pricy. Is there a cheaper solution out there or is this my only option. I am trying to go with 70% of my weigh up front and I don't want to add weights to the inside of the tire as it will stress the drive tran. Any help would be appreciated thank you
02-08-2014, 04:10 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Knuckle weights |
02-08-2014, 04:11 PM | #3 |
Rock Crawler Join Date: May 2012 Location: Washougal
| Re: Knuckle weights
Check out bluemonkey rc. Depending on what knuckles you run they have some good stuff.
02-08-2014, 04:23 PM | #4 | |
| Re: Knuckle weights Quote: X2! | |
02-08-2014, 05:26 PM | #5 |
| Re: Knuckle weights
Any sujestions on how much weight i can fit up from running tsock offset wheels. i would like to add as much as possible.
02-08-2014, 06:48 PM | #6 |
02-08-2014, 11:39 PM | #7 |
| Re: Knuckle weights
Currently lisi bead locks will be upgrading to vanquish soon.
02-09-2014, 12:21 AM | #8 |
| Re: Knuckle weights
DLUX v2 knuckles FTW!
02-09-2014, 08:06 AM | #9 |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
| Re: Knuckle weights
Yep. You really cant go wrong with the Dlux knuckles. The list of benefits is huge. Dlux custom knuckles V2! |
02-09-2014, 08:12 AM | #10 |
| Re: Knuckle weights
And if you really want to get crazy, you can upgrade to the OFNA style stub shaft. Now you can have huge bearings, a huge stub shaft, an unbreakable hex pin. This is on top of all the other benefits. Its really a step towards a bulletproof front end AND the weight of the knuckles is just a bonus. The bearing I run is all the way on the left. |
02-09-2014, 02:45 PM | #11 |
| Re: Knuckle weights
Is there a way to run the bearings and still keep my vanquish shafts??
02-10-2014, 09:03 AM | #12 | |
You go from a 10x15 inner and 5x11 outer to a 10x16 inner and 5x13 outer on my knuckles. It may not seem like a ton but it will add a lot of reliability in the bearing area. | |
Knuckle weights - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
