02-17-2014, 10:31 PM | #1 |
Newbie Join Date: Sep 2013 Location: liberty
| Cutting the Wraith Chassis
Ok guys I have done a lot of search button on here and google and I am thinking about cutting my wraith chassis trying to get rid of that station wagon look. I am going for a more ultra4 look, plus my damn hands are to big to get in that tiny space to change the battery. I would like to get yalls opinions on the best way to do this (with pics). I have seen some rigs on here where they just cut the chassis behind the seats and that look is ok but im not really wanting the truck look, I want something that flows. I need help I would like to see some pics of your rigs with chassis mods. Need some ideas thanks in advance |
02-17-2014, 10:47 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: Duluth, MN
I just dremeled away, then used the original plastic upper links to create a fastback look, then later added 2x factory aluminum lower links as cross bars to add strength and durability. If you wanted you could probably get creative with lexan, aluminum, styrene, etc and make a body panel to go over it Forgive my upside down pics... No idea how/why they are like that Last edited by THX_138; 02-18-2014 at 08:04 AM. |
02-17-2014, 10:52 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Re: Cutting the Wraith Chassis
as sean said... get that dremel out and use the stock links! |
02-17-2014, 10:53 PM | #4 |
Here is how my wraith looks now. Not exactly sure why the pic is sideways but oh well lol.
02-17-2014, 11:07 PM | #5 | |
| Re: Cutting the Wraith Chassis Quote:
02-18-2014, 01:58 AM | #6 |
Newbie Join Date: Dec 2013 Location: La Grange
Like this? Cut, heat, and bend. Drill hole in center of tube to attach large rod end, eyeball the angle an length. Takes some time, no pics as i did it, sorry.
02-18-2014, 08:40 AM | #7 |
this is how mine were done...
02-18-2014, 01:00 PM | #8 |
How did you connect the links to the roof where you bent it down?
02-18-2014, 01:06 PM | #9 |
What did you use to connect here
02-18-2014, 01:59 PM | #10 |
| Re: Cutting the Wraith Chassis I used the threaded rods used to attach rod ends to axial lower links, the same ones also that bolt the lower links to the skid plate. I used 1 of those long tip lighters like the ones used to start gas grills, heat slowly all around where you want it bent but not to much flame cause the plastic will splinter. You can see in my pic where i removed the gusset under the top bar at the B pillar wher it is heated and bent. Cut the bar long then trial fit so you dont cut off too much. I used a longer screw in the side bar where the rod end will attach.
02-18-2014, 03:12 PM | #11 |
I used a longer screw, with extra spacers I had from another build and used left over shock pistons for the washer..it went thru one of the existing holes in the link for a perfect fit (on each side of course)
02-18-2014, 04:40 PM | #12 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Havent quite decided if I am going to do this, if I do, I will benf the roof
02-19-2014, 12:58 PM | #13 |
Pebble Pounder Join Date: Jun 2009 Location: prairie du sac
Watch Harleys $50 budget build. Makes it look real easy. And its the best looking free mod u can do. I did it as I was building my kit. Real easy
03-01-2014, 10:51 AM | #14 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
I tried to keep as much of the roll cage as possible. Heated and bent then Fab'd a couple of short links to tie back to the rear of the frame. [IMG]//https://www.dropbox.com/s/wdtf2acaexdlief/photo%201%20%2818%29.JPG[/IMG] https://www.dropbox.com/s/xkjxwx84j2...20%2811%29.JPG |
03-01-2014, 12:09 PM | #15 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
I went to the Local auto parts store and picked up brake line. |
03-02-2014, 12:17 AM | #16 |
Newbie Join Date: Nov 2013 Location: SoCal
| Re: Cutting the Wraith Chassis |
03-02-2014, 08:11 AM | #17 |
Pebble Pounder Join Date: May 2008 Location: tucson
03-02-2014, 08:54 PM | #18 |
Newbie Join Date: May 2013 Location: Burlington
Here is how mine looks. Sent from my SPH-L720 using Tapatalk |
03-02-2014, 09:27 PM | #19 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
dig the trailing arms! |
03-02-2014, 09:33 PM | #20 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
All thread and aluminum tubing with rod ends: |
Cutting the Wraith Chassis - Similar Threads | ||||
cutting the cage on the wraith, truck style | twilight | Axial Wraith | 6 | 12-21-2011 08:49 AM |
Cutting chassis | bigdodge88 | Tools, and Procedures | 2 | 11-11-2008 06:33 AM |
cutting tranny when cutting bottom of chassis off... | dieselfuel | Newbie General | 1 | 02-23-2006 08:10 PM |
cutting the chassis | jordanator62 | Tamiya Txt-1 and Juggernaut | 16 | 07-18-2004 07:20 PM |
