02-21-2014, 10:10 AM | #1 |
Newbie Join Date: Feb 2014 Location: Iceland
| Pinion hex screw
Anyone know the hex size in the pinion screw?, always busting the spur so I'm gonna put a bigger spur and smaller pinion Sent from my iPad using Tapatalk |
02-21-2014, 10:14 AM | #2 |
| Re: Pinion hex screw
I think its 1.5mm.....
02-21-2014, 10:15 AM | #3 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
1.5mm Sent from a big fat phone |
02-21-2014, 10:29 AM | #4 |
Thanks Sent from my iPad using Tapatalk |
02-21-2014, 10:44 AM | #5 |
Pebble Pounder Join Date: Nov 2013 Location: HILLBILLY ACRES
What pitch spur and pinion are you using? Brushed or brushless motor?
02-21-2014, 12:16 PM | #6 |
What about the spring between the nut and the spur, is it suppose to be fully compressed when assembled?
02-21-2014, 03:22 PM | #7 |
I'm using 48p, brushed motor
02-21-2014, 03:52 PM | #8 |
I might get flack for this but the spring your talking about is for the slipper clutch....i never understood why those are on scalers...racers yes....i jam mine down....sonits locked.....its supposed to be adjusted but honestly I don't know one would do it on a scaler Sent from a big fat phone |
02-21-2014, 09:28 PM | #9 |
| Re: Pinion hex screw You may want to switch to 32p, they are stronger. Also, are you running in dusty, sandy areas without the spur cover? That would eat a spur too. If your slippetis tightened all the way and you jerk back and forth, or jump alot, that could be another reason.
Pinion hex screw - Similar Threads | ||||
What size hex key for grub screw on pinion ? | cdl1003 | Redcat Crawlers | 5 | 02-14-2013 01:50 AM |
pinion grub screw hex size | 99xjlove | Losi Mini-Rock Crawler | 3 | 05-09-2012 08:32 PM |
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
Hex Screw Kit for CR-01? | kulangflow | Tamiya CR-01 | 8 | 08-25-2008 06:32 PM |
