knuckle weight help i just got my rc bros knuckle weights and they dont fit on my wraith. i cant figure out if im doing anything wrong the mounting holes match up but the inner ring is so far forward that my hex wont fit on. do i need new knuckles?? if any one has any pictures that would be greatly appreciated thank you |
Re: knuckle weight help What type of wheels are you using? I think they need atleast a 350 sized vp hub to clear |
Re: knuckle weight help even with out my wheels on the touch my inner hex. running twister rims with mud country tires |
Re: knuckle weight help What rims??? What weight set??? |
Re: knuckle weight help rc4wd twister rims but with no weigh t and not rims on my wrait the weight holder will not fit on my knuckles they hit the hex on the axle shaft |
Re: knuckle weight help Post a picture so ,everyone can get a visual how you mounted them. |
Re: knuckle weight help Im deployed right now cant upload pics |
Re: knuckle weight help I just got rcbros kit for my wraith last week and all fits perfect mine has factory hex's with vp hubs and wheels looking through box for original parts to check from what I see it won't work on my original hubs either hope that helps good luck while deployed thanks for your service USA USA USA |
Re: knuckle weight help Thank you ill have to order some VP knuckles then. |
