03-04-2014, 07:30 AM | #1 |
Newbie Join Date: Feb 2014 Location: Channahon
| Articulation problems
Ok I finished my rig and I seem to have articulation problems, as in not enough. I am using the vanquish track bar option and wondering if that might be it. The back has a ton of articulation but the front not so much. Any ideas or set up advice?
03-04-2014, 07:41 AM | #2 |
| Re: Articulation problems
It should have 1 tire height or a little less. Got pics? |
03-04-2014, 07:43 AM | #3 |
Quarry Creeper Join Date: Nov 2012 Location: Springfield, MO
x2 on the pics. Need more info such as shock length, links using, etc...
03-04-2014, 09:40 AM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
You removed one of the front top links, correct? 4 link + Panhard = no movement.
03-04-2014, 10:47 AM | #5 |
Yeah I removed the other link, using vanquish titanium links. Shocks are 95 mm integy shocks with working resiviours. Also I have the brg shock mounts n front and back.
03-04-2014, 10:49 AM | #6 |
Do I want the shocks as straight as possible, used to having the shocks at a angle on my Losi 22t
03-04-2014, 11:54 AM | #7 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
First off if you want more flex, get slightly longer shocks. I have Gmade 103mm shocks on my wraith and I love them. You would want the top of your shocks on the mounts closest to the middle of the chassis. That's how I had mine set up before I put a lowering kit on it and it worked great. Pictures would definitely help. I'm not sure if you can really see it here, but my shocks are leaning more towards the center of the chassis. |
03-04-2014, 02:04 PM | #8 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
I get 6+ and that's not all because the chassis hits front and rear (4ws) on the servo. I got to make a custom chassis to accommodate my mods. My wraith is slammed too. I recommend going 3 link if you haven't or checking your shocks. I have 103 mm which is very common. I recommend 90-110 mm. Also check your drive shafts cause they might be hitting. Is it a kit or rtr. If its a kit and you put the wrong links on that's definitely the problemo Sent from my iSlow using Tapatalk |
03-04-2014, 02:56 PM | #9 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Too much articulation is bad. About 1 tire height is all you want.
03-04-2014, 03:30 PM | #10 |
| Re: Articulation problems |
03-04-2014, 03:43 PM | #11 |
03-04-2014, 07:01 PM | #12 |
Rock Stacker Join Date: Dec 2011 Location: pell city
What parts did seb rc shop use to get all that flex
03-04-2014, 08:55 PM | #13 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
I was waiting for that glass counter top to shatter in that video
03-04-2014, 08:56 PM | #14 |
Rock Stacker Join Date: Jan 2014 Location: Reseda
You can use those servo de-wangers that move the servo inwards a bit to give more clearance.
03-04-2014, 09:05 PM | #15 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
03-04-2014, 09:21 PM | #16 |
I'm using the Losi comp crawler shocks. It is a kit, I did the BGR front and rear shock mounts. They are more like shock hoops then the three hole plastic mounts.yes I am using the vanquish track bar and did the servo relocation as well
03-04-2014, 09:23 PM | #17 |
I have the king shocks that are 110 but really don't like them. More for looks then actual function. Also have the integy resiviour shocks they are 95mm but the shock body is really big. Just got the Losi comp crawler bottom fill shocks. So far works killer.
03-04-2014, 09:43 PM | #18 |
I believe this was all covered in the first response to the op. |
03-05-2014, 06:40 AM | #19 |
Articulation problems - Similar Threads | ||||
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
New RC4WD Bully Articulation Problems | speed6 | RC4WD Bully | 16 | 11-01-2009 07:55 AM |
articulation | munky | Axial AX-10 Scorpion | 17 | 10-26-2009 10:27 PM |
articulation problems | dutchcrawler | Tamiya Clod Buster | 6 | 02-19-2007 11:26 PM |
