03-08-2014, 07:36 PM | #1 |
Newbie Join Date: Nov 2009 Location: Mt. Sterling
| Pinion bushing problem
I am running overdrive front HD stock ratio rear gears using traxxas bushings on the pinions in vanquish axles with vanquish lockers. My problem is I am constantly having to replace the front bushings, about every 2-3 packs. Never have replaced rear bushings. I am running a mmp/ roc 412 3100kv attached to a super shafty bomb proof ax trans w/mip shafts. I was wondering if this is a problem with running over/under gears with brushless power or if I have other problem? Thanks for any help/info
03-08-2014, 08:20 PM | #2 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
| Re: Pinion bushing problem
I change both out every 2-3 packs also. Looking at getting those D-lux 16mm inner bearing axles. I have have noticed that my outter bushing gets lose in the housing.
Pinion bushing problem - Similar Threads | ||||
Traxxas bushing vs. HPI bushing. | day215 | Axial XR10 | 9 | 10-07-2011 06:00 AM |
pinion problem | foproy | Electronics | 8 | 09-16-2011 01:49 PM |
pinion problem | GearLoDriveSlo | Team Losi Comp Crawler | 12 | 04-25-2010 06:14 AM |
Pinion problem | armalite_ar50 | Redcat Crawlers | 5 | 04-19-2010 09:47 AM |
pinion problem | GReddy | General Crawlers | 6 | 03-12-2005 03:36 PM |
