03-21-2014, 05:29 AM | #21 |
| Re: allanons DMG Dual Shock Shortback Stiffy Build!
Awesome. Droooooooooling
03-21-2014, 06:43 AM | #22 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Looking Good!
03-21-2014, 08:11 AM | #23 | |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| allanons DMG Dual Shock Shortback Stiffy Build! Quote:
Can't let this one go... The GCM's are MUCH more durable than the VP's. If you want pretty, stick with VP. If you want rugged, get the GCM's. As for the cHubs and Knuckles, stick with VP. The VP cHubs couldn't fit any better/tighter to the GCM's. Last edited by TheScaleAddict; 03-21-2014 at 08:15 AM. | |
03-21-2014, 09:58 AM | #24 |
well i want durable for sure..I do beleive it will be the GCM's |
03-21-2014, 10:09 AM | #25 |
03-21-2014, 10:13 AM | #26 |
good enough for me I love this chassis...jerry does amazing work..
03-21-2014, 11:45 AM | #27 |
| Re: allanons DMG Dual Shock Shortback Stiffy Build! |
03-21-2014, 09:45 PM | #28 |
Do you feel the dual shock setup makes the difference or what? I want to save up for a stiffy but havent decided short or long back. |
03-21-2014, 09:58 PM | #29 |
my plans for this are not set in stone but this is pretty close: Tekin 412ROC 3100kv Castle Creations Mamba Max Pro Sensored SuperShafty Bulletproof Wraith Transmission GCM Metal Head Wraith A-13 Axle Housings Vanquish CVD Axle Shafts MIP Driveshafts Axial Rear Axle Shafts Gmade 103mm Piggyback Shocks Pro-line 118mm Powerstroke Shocks Vanquish C-hubs Vanquish Knuckles Vanquish Steering Linkage Vanquish CMS Vanquish Pan Hard Traxxas Revo Links Pitbull Rock Beast II Motoworx Racing 2.2 8 Spoke LE Aluminum Wheels Warn 9.5 CTI Winch Things yet to be determined: Front bumper, needs to have winch mounts Body panels Lights TX/RX Battery, 3s 5000maH minimum I know this is gonna cost plenty , but a little at a time will make it ok Last edited by allanon1965; 03-24-2014 at 11:06 PM. |
03-21-2014, 10:00 PM | #30 |
| Re: allanons DMG Dual Shock Shortback Stiffy Build! Do you feel the dual shock setup makes the difference or what? I want to save up for a stiffy but havent decided short or long back. I do feel it makes a noticeable difference...although I dont have the shocks that are recommended for this yet, the ones I am using prove to me that it is a nice upgrade. It seems to flow much more smoothly over obstacles in my yard. Now I need to get it out to a more diverse terrain. |
03-21-2014, 10:10 PM | #31 |
I do beleive I will buy another stiffy kit, but this time a longback one...or maybe the widows web stiffy Last edited by allanon1965; 03-23-2014 at 07:28 PM. |
03-23-2014, 09:37 PM | #32 |
I put in some lights I had laying around, these will be replaced by better ones at a future time, but for now they work. I mounted the rear lights to the roof panel because I didnt want to mount them to the stiffy...its too pretty I really need to get a better camera... |
03-23-2014, 10:57 PM | #33 |
thanks! its a little ugly right now, but it will get better looking as I get more money! I am kinda liking the scx10 axles more and more as I drive it...I am debating whether or not to go with wraith style axles or stay with the scx10 axles... |
03-24-2014, 06:21 AM | #34 |
I'm sure Chris (GCM Racing) will build the tubes at whatever length you want. Wider than a SCX10 and more narrow than a Wraith. That way you can have a bit of the best from both worlds. ;) Only trick would be in fabricating your shafts. The solution to that isn't too difficult though.
03-24-2014, 07:47 AM | #35 |
I never thought of that...maybe I could have them make the axles too? make it a package deal with a couple spares as well..
03-24-2014, 08:00 AM | #36 |
| Re: allanons DMG Dual Shock Shortback Stiffy Build! He can't/doesn't make CVD's though. I would suggest getting the longer Wraith CVD's and cutting them down to the length you'd need. As for the rears, you have more options there. You could get Creeper Bob to hook you up with custom length Ti axles, or you could fabricate your own from the longer Wraith ends. Personally, I would do it myself. Once I had them cut, I'd hand file the tangs to get them 'just' right. I'd recommend using the Locked Up RC FI spools. I have nearly everything you'd need in stock. It's not too terribly difficult, and the end result would be worth the effort.
03-24-2014, 08:06 AM | #37 |
sounds like a plan to me...I have the locked up FI spools I got from you already in my blue flame wraith so I would definitely do another set in this one! Now to figure out what width would be the best to go with...
03-24-2014, 11:14 PM | #38 |
got my MIP Driveshafts put on the DMG Stiffy wraith today and took a few pics of both of my wraiths on the woodpile
03-25-2014, 07:30 AM | #39 |
Looking good!
03-25-2014, 08:00 AM | #40 |
