03-17-2014, 08:58 AM | #1 |
Newbie Join Date: Mar 2014 Location: Bonaire
| Poison Spyder RTR
Just got my Wraith and was wondering what to do to it first? I am sorta new at crawlers.
03-17-2014, 09:25 AM | #2 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: Poison Spyder RTR
Moving battery to front is a great place to start their are many threads here showing a few different ways and its free
03-17-2014, 09:26 AM | #3 |
Ok thanks!!
03-17-2014, 09:26 AM | #4 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
First grab a Castle Creations BEC. And then watch Harley's budget build video series!
03-17-2014, 09:31 AM | #5 |
Pebble Pounder Join Date: Mar 2012 Location: York
I would re-glue all the tires or switch out to 2.2 beadlocks...I had a RTR Wraith and the tires started coming off the rims after a week.
03-17-2014, 09:41 AM | #6 |
Do I really need the BEC if I am not running a 3s?
03-17-2014, 10:18 AM | #7 |
Rock Stacker Join Date: Jan 2014 Location: Essex U.K
First things i did was move the battery upfront, make sure all the screws are tight especially the servo ones an for the servo mount s mine came loose, and replace the stock plastic steering linkage. Other than that have fun with it and replace what you break! I added a bec just incase. Also worth water proofing everything as you never know! Axial Racing - How to Waterproof your SCX10. You will soon find out that its an expensive hobby! |
03-17-2014, 10:51 AM | #8 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
If you don't want to get addicted and spend a fortune...delete this website from your bookmarks otherwise carry on. |
03-17-2014, 11:04 AM | #9 |
03-17-2014, 11:27 AM | #10 |
So will I need the BEC if I run a 2s?
03-17-2014, 11:42 AM | #11 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Poison Spyder RTR |
03-17-2014, 11:48 AM | #12 |
| Re: Poison Spyder RTR the BEC is mainly for running a high torque servo, which you will want to do soon as the stock servo leaves much to be desired. It will fail fairly soon after you get going in the rocks. Mine failed after about 15 minutes in the rocks. when you replace the servo, go for one with at least 300oz of torque. the BEC will prevent brown outs or glitches in the electronics system due to the higher torque servo drawing more current, be it 2s or 3s JUST GET ONE! Last edited by allanon1965; 03-17-2014 at 07:31 PM. |
03-17-2014, 04:40 PM | #13 |
When you pinch your front tire against a rock and then you turn the wheel and push the rock away that is servo power. Can't do that without a BEC!
Poison Spyder RTR - Similar Threads | ||||
Poison Spyder RTR or regular RTR? | djb2 | Axial Wraith | 20 | 11-11-2013 01:26 PM |
Poison spyder or rtr wraith | ax10tn | Axial Wraith | 6 | 09-02-2013 07:42 PM |
Newbie RTR Poison Spyder experience. | Cale262 | Axial Wraith | 42 | 08-23-2013 10:36 PM |
