03-21-2014, 02:20 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
I just received in the mail Vanquish Products limiting straps. Just at first glance they look amazing better than the pictures on the web site. I only wish they had made them a bit longer because now my suspension is compressed. I like to have my front end higher than the rear. If the straps were a little longer I could bolt down the lower part of the strap to the inner side of the shock mount. Never had any issues with the shock talking the load of the axle. In this case I think these straps should be more for looks than for actual performance. Just my opinion. Last edited by THX_138; 05-23-2014 at 12:22 AM. |
03-21-2014, 04:11 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Vanquish Products limiting straps
"Compressed" a little is good. The whole point is to prevent the shock internals from taking the load of limiting extension. The strap should go fully tight before the shock is at full extension.
03-21-2014, 04:51 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
For crawling purposes I've caught myself debating using a sway bar setup or limiting straps. Granted, these two perform different jobs but I'm curious which would be the better choice if you were to only use one? Sway bar links would help with stability, while keeping one side of the axle from dropping too far below / above the other compared to the vehicle. Limiting straps would keep the wheel from falling in a hole, and may act as a rudimentary sway bar in certain situations.. |
03-21-2014, 04:55 PM | #4 |
Sevastra I agree. You should try them they look amazing on the rig.
03-21-2014, 07:55 PM | #5 |
Rock Stacker Join Date: Jan 2014 Location: Reseda
Now I know what those are for. I would try those instead of sway bars myself. Hey MM have you stopped the XD piggybacks from leaking?
03-21-2014, 09:40 PM | #6 |
Newbie Join Date: Feb 2014 Location: sacramento
I too did not know the purpose of those straps till right now.. anyhow do they make different sizes or only different colors ?
03-21-2014, 11:42 PM | #7 |
No luck on the shocks from leaking. Im not going to give up on them yet. Im about to go mid evil on thier asses lol. To my knowledge VP only makes different colors. Maybe in the future they will make different sizes. Last edited by THX_138; 05-23-2014 at 12:23 AM. |
03-25-2014, 08:31 AM | #8 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
They make two different sizes. One for SCX10 and one for Wraith. I purchased the SCX10 set that runs 2 3/4" I think but I run 4 inch shocks so I can't use them. The Wraith version are 3 1/4 inches I believe and would have worked much better for this application. Sent from my SCH-I545 using Tapatalk |
03-25-2014, 08:39 AM | #9 |
DowntownScience what I did was mount one side of the strap to the chassis and the other end to the lower shock mount. I feel it looks better and my suspension is more free now. This is where the straps are now. Last edited by THX_138; 05-23-2014 at 12:21 AM. |
03-25-2014, 05:00 PM | #10 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
When suspension and steering components are no longer the limiting factor when flexing, it becomes the shock, hence the need for limiting straps. Sway bars lessen the suspension's articulation but provide stability. They both have very different applications. That being said, the VP limiting straps sure look great. Awesome scale detail.
03-26-2014, 07:39 AM | #11 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Vanquish Products limiting straps |
03-26-2014, 08:53 AM | #12 |
Great idea. I'll have to play around with mine again. Thx. Sent from my SCH-I545 using Tapatalk |
03-26-2014, 12:30 PM | #13 |
Amazing set up Rolandrockshop. Amazing!
03-26-2014, 03:13 PM | #14 | |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Vanquish Products limiting straps Quote:
03-28-2014, 08:25 AM | #15 |
I think I was off on my wraith size of 3-1/4. Your measurement sounds like the ones they spec as wraith on their site. They do just have one size for each scx10 and wraith. Sent from my SCH-I545 using Tapatalk |
Vanquish Products limiting straps - Similar Threads | ||||
Best limiting straps? | JUGGARNAUT | General Scale Talk | 6 | 12-25-2011 08:56 AM |
Limiting Straps | trulyoffroad | Scale Accessories | 3 | 01-20-2010 08:39 AM |
Limiting straps | AdamF | General Crawlers | 52 | 03-07-2006 04:18 AM |
limiting straps... | fastg60 | General Crawlers | 6 | 12-27-2005 09:44 AM |
limiting straps? | MaxxZilla | General Crawlers | 4 | 05-19-2004 05:04 PM |
